SOURCE: Top light on HP 6122 ink jetprinter keeps blinking
This light will blink when the top cover is not properly shut, so the easy first step is to check that the cover is closed properly.
If that does not help, then one of the cartridges is not being recognized. See here to determine which cartrdge is the issue.
You can then remove and reseat that cartridge, also try cleaning the cartridge contacts as shown here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
SOURCE: how to enlarge fonts on hp deskjet d1500 series
go to the printer settings your will see font enlarge click on it
rate it
SOURCE: Printer won't print. Green light blinks once, then
5 times says the printhead is bad and needs to be replaced.The part number is stamped on the side so you can get the right one.
