Sanyo VPC-X1250 Digital Camera Logo
Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Usb device not recognized - Sanyo VPC-X1250 Digital Camera
Nomad
Level 2:
Sergeant:
  • Expert 166 Answers
  • Posted on Jul 04, 2011
Nomad
Expert
Level 2:
Sergeant:
Answers
166
Questions
Helped
72231
Points
505
Assuming a healthy camera battery, capable of holding a charge - try another cable / USB port / Computer first.
When it's same on all USB ports and a different computer, wiggle the USB connector on the camera carefully. If the connection is ok at some point, it's the camera USB port making bad connection.
I connected a USB stick to The USB port in my LG 42LH2000 but I can't get it to work, there's no USB options on input. Can someone please help
tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 • Computers & Internet
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
USB DEVICE NOT RECOGNIZED One of the USB devices
This may cause if your USB port is out of order. Or your pen drive is not in good condition.
Think this is helpful !
I just bought a new Gateway NV53 laptop but my P4350 Lexmark all in one printer does not recognize any of the USB ports.
Did you check whether the USB ports are recognizing other USB devices such as Microvault or Flash Drive? If all other USB devices are recognized except the Printer, then reinstall the USB Drivers. You can uninstall the USB drivers from the Device Manager and restart the Computer. The USB Devices are listed under Universal Serial Bus Controllers in the Device Manager.
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
1helpful
2answers
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
