You mean that it is showing you a Mirror look if like that then please refit the display. to refit your Display use the T6 screw driver to open your mobile there are 6 screw's first 2 screw's are below or back cover then other 4 screw's in front side of mobile remove the front penal then there you will get thous 4 screw's remove all 4 screw's take out the mother board after doing this remove the display shield it is metal shield remove the display with its display connector that is placed behind the Bord agen there you'll find the metal cover remove that then unplug the display with display connector and refit that on same place then refit all the things which you have removed then start then mobile it will get solved is not then you should it ones agen if your not a mobile technician then please dont try to do this.
If your not a Mobile Technician the Please Visit your nearest Nokia Service Center (Nokia Care) or Visit any Mobile Repair Center they will Doit in proper method.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up & Testimonials //
