Joico Ice Spiker Distortion Styling Gum 3.4 Oz Gel Logo
Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm almost out of my Distortion gel and need to find out where I can purchase more, on or off line.
Anonymous
Level 2:
New Friend:
  • Expert 108 Answers
  • Posted on Jul 04, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
108
Questions
0
Helped
27325
Points
171
You need any problum about Joico Ice Spiker Distortion Styling Gum 3.4 . At see here
http://www.amazon.com/Ice-ICE-Distortion-Styling-Gum/dp/B000NVZLE6
Toshiba 32AF45 CRT TV Distortion and Flicker During Moments of High Contrast?
Check its main power regulator section circuit. Replace all the electrolytic capacitors there. This is a power supply fault.
I just purchased a Takamine acoustic/electric EG 350 SC which sounds great until I plugged it into a Mackey sound board. I sounded like distortion was coming out. In other words, it sounded like ****. I...
I ASSUME that you plugged your guitar into a DI box that then used BALANCED XLR cable to the Mackie board??? The guitar generates line level and the Mackie board inputs are mostly mic level... you will get distortion if you overdrive the Mackie board. You could try going into line level jacks, HOWEVER if you go any distance balanced interconnects must be used. Even the line level jacks require using TRS balanced cables. Try is using a DI box, and preferably one with a gain switch. Also fiddle with the ground lift switch on it for least noise or hum. I use the LiveWire brand DI boxes and they seem to work fine. Then it is important to set the gain with the trim on the MAckie so you don't clip. Also be aware that an acoustic guitar can "hear" speakers and you can get feedback or regeneration that will sound like you are in a cave.
I just purchased the behringer djx 700, and the channel 2,3,4 are all distorted when i play music. Even when i listen to it through headphones you can still hear the heavy distortion. What can i do to...
You are probably overdriving the inputs. You haven't told us the source of the inputs and we can't guess where they may come from. You need to read the manual and make sure your source outputs are within range of what this unit requires.
Iwanted to get arefund on advil liquid gels capsules 200 mg 40 liquidgwels
If you have the receipt from where you purchased it, return it for refund. If you don't, they might not give you a refund or they'll give you store credit on a their store gift card.
-OR-
If you purchased this product months ago without knowledge of where you bought it from,
contact customer service representative toll-free at:
800-882-3845Monday - Friday, 9 a.m. - 5 p.m. EST.
I purchased a Vivitar 2.2x lens for my Lumix DMC FZ18 camera & I'm getting a lot of distortion. Suggestions?
It's a cheap(ish) generic screw on lens multiplier and so compatibility with anything it's screwed onto is a matter of pot-luck, especially as the conversion factor is so high.
There is nothing you can do, other than to try alternative brands (preferably not exceeding 1.4x) or to obtain the expensive Panasonic version which is designed to be compatible with your camera. Even the official product will produce some distortion (usually barrel distortion) and most likely a fair bit of chromatic aberration. It's just usually less adverse than with the generic products.
2answers
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Top Joico Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Joico Health and Beauty Expert? Answer questions, earn points and help others
