Kenmore 46462 Front Load Washer Logo
Anonymous Posted on Aug 24, 2008
Kenmore HE2 flashing lights
I have a kenmore he2 and the lights are flashing. I have had this machine for 14 months. called Sears and it is going to cost me 400 dollars. Any suggestion about to fix this machine. Any guidance or directions will be much appreciated. Kenmore HE2 110.46462501 stopped in the cycle with some of the status lights lit, lights around the cycle ring flashing. Restart on 'drain and spin" cycle, pump runs for a period then tops with Status lights 'add garment', 'rinse', and 'add garment' lit. The 'wash', 'spin', 'controls locked' and 'door locked' are not lit.  Cleaned out the pump trap as per suggestion. Found a lot of stuff - change, nails, construction screws and a small gold chain. Removed the pump and checked teh impeller for damage, obstructions. There was also a fair bit of goo in the bellows with the float ball, which I cleaned out. I primed the system with about a gallon of water, then ran 'spin and drain' cycle. Cycle starts by pumping out all the water. The pump then runs (mostly) dry pulsing the remaining water in the drain line, and then ends in the flashing light state. Other cycles behave same. Pump runs, no water is added, and ends in flashing light state. Seems like system senses water in the tank, and tries to pump dry. Failing to detect empty state, it gives up. Any  next step suggestions please? --RRLee
  • Anonymous Mar 26, 2014
    half way through cycle, the machine stops, smells hot and all light flash.
Anonymous
Level 3:
Master:
  • Master 521 Answers
  • Posted on Aug 24, 2008
Anonymous
Master
Level 3:
Master:
Answers
521
Questions
0
Helped
162841
Points
1218
Did the technician point out wat needs to be repaired
  • Anonymous Aug 24, 2008
    also check for the sensor unit which detects water in the tank.also for more information and cheap replacement parts with fitting procedure can be obtained from a link below:
    www.repairclinic.com
    thanks.keep us updated.
    regards.
    fixya expert team
    pls do rate the solution
Error code 1h on kenmore he plus2
Oddly, I don't find this error code. In fact, every one of the error codes for the Kenmore He2 begin with a letter, not a number.
Kenmore HE2 Front Load Washer Error Codes Sears PartsDirect
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Kenmore HE2 Plus Model# 11047512600 When pushing the start button it will just beep 3 times and not do anything, door won't lock or start cycle. No error codes are displayed. Whats wrong?
Hello Jason,
Regarding
  • There is a communication error in the control board.
  • Also the door Latch assembly may be defective. Check & replace as necessary.
Here is a link to Sears parts direct.
KENMORE RESIDENTIAL WASHER Parts Model 11047512600 Sears PartsDirect
Our he2 dryer is flashing a F
Get online ask Kenmore.Did u lose book?
Need part number for my kenmore he2 plus washer's drain pump. I need to replace it due to a continuing F21 error code msg
Sears has a fantastic part locator on line try that just surf the sears site you ll find it ,probalby even have a number to call just in case
3helpful
Giving a F- on the time screen and is not draining properly
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/639d1187051794-he2-error-codes-he2-error-codes.pdf
That list all the service codes for that washer.
had an old pressure switch that I thought was the problem I had from something else a year ago
That was the washer not starting, all kinds of lights
I took the back and top off and reconnected all the plugs.
Had a loose connection somewhere, it worked after that.
I blew into it and put it back on.
The rattleing quit in the pump after it pumped out, while the drum was spinning slow.
Now working ok
Alexander
vince
