HP Compaq Presario F750US Logo
Posted on Jul 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
File\windows\system32\winload.exe missing or corrupt status:0xc000000f do not have installation disc to fix problem
Anonymous
Level 3:
  • HP Master 6,487 Answers
  • Posted on Jul 03, 2011
Anonymous
HP Master
Level 3:
Answers
6487
Questions
6
Helped
1557030
Points
18452
You can do these procedure to correct the problem , Start in safe mode press F8 during boot up of your computer and select the C> prompt. Use the following commands: bootrec.exe /fixmbr and then bootrec.exe /fixbootand hit enter.
But after doing that procedure and problem is still there you really need here a operating system dis to correct the problem or a recovery disc for your computer that you can request from the manufacturer.
1 Related Answer
Anonymous
  • 285 Answers
  • Posted on Jul 22, 2009
SOURCE: system32.
I'd try to insert my Windows dvd, boot from it and try to repair the installation. If thatdoesn't work, try to backup any data you want if Windows still lauches, and else you will have to reinstall Windows, I'm sorry.
I hope this helps,
Yannick.
File missing
WHAT WHERE YOU DOING WHEN THE PROBLEM ACCURD.
A INSTALLATION ?
Error 0xc000000f while formatting hard drive
try some formating toos .. like hiran boot cd or disk or diskformater ...u can use usb bootable device to install windows, u can make ur personal pen drive to bootable pen drive.
4answers
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
1helpful
My laptop is saying i need to insert windows installation disc and restart comp file windows /system32/winload.exe status oxcoooooof info this selected entry could not be loaded because the application...
your boot record is corrupt..
get the recovery disk or install disc
then reboot and boot the install disc
the first screen has a "repair startup" option
goto there... it is all then obvious
1helpful
When i start up my computer it goes straight to boot manager and gives an error code file\ windows\ system32 \ winload exe,,, status 0XC000000F file missing or corrupt, what is the issue please, system is...
The problem you have is with the system boot files. There is a corrupt file and that is stopping the system from booting.
Press F8 as the system starts up, that will let you into the special boot menu and hopefully will give you the option of repairing your system. The timing can be quite tricky as there is only a very short time window. Trying a few times should get it.
Hope that helps.
1helpful
System32.
I hope this helps,
Yannick.
Cant get my laptop to up load
Do you have any important files that you want to back up first?
If not using the restore function will be the easiest route.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
