Question about King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P
My 5' King Kutter brushog drive shaft gets jammed. I have it apart and there seems to five inchesw or so yet to compress but won't.. Can I be copmpressing air which prevent the two tubes from mating completely? I have removed any burrs that might have been there, had to drive the two apart with steel bar and sledge.. They go together well now except for the last five inches! THANKS
  • Emmett McPherson May 30, 2012
    Did you size the PTO shaft according to the instructions in the manual?
5 Suggested Answers
SOURCE:
  • 97 Answers
SOURCE: my king kutter till will not hold gear oil.
If it is leaking around the shaft you can replace the seal.
Posted on Mar 25, 2009
  • 496 Answers
SOURCE: just bought a 6 ft king kutter brush hog - no
I took a stab at this... I hope this is what you are looking for:
http://www.kingkutter.com/downloads/manRKRK.pdf
Posted on Aug 31, 2009
mister_b_65
  • 74 Answers
SOURCE: how much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
Posted on Apr 09, 2010
  • 17 Answers
SOURCE: Is the King Kutter ATV SeederSpreader suitable for
lime should be applied at 50 lbs per 100 sq ft which is heavy mark off 100sq and see what it takes at 3mph
Posted on Feb 09, 2011
How to get bearing out of my king kutter 72"finish mowers, the repair kit comes with snap rings, my has a nut and a star lock washer under the nut. The bearing won't come out of the top of the spi
Without seeing it I can't be sure of your exact problem. But on mine, the washer under the nut has tabs I had to bend down to enable the nut to come off. Then I had to use snap ring pliers to take the snap ring out. Be careful here, as the rings can be under a lot of pressure and they can really fly, so use safety goggles. On that mower deck I was able to hold the blade in place with a piece of 2x4 stuck in the deck, so I was able to loosen the nut with a breaker bar. On my other deck the blade turned, so I had to use a large pipe wrench to hold the shaft on the bottom while I loosened the nut on top. Unless yours is really different, the whole spindle assembly comes out by removing 4 small bolts.nuts. This makes it a lot easier to work out in the open.
Dec 02, 2017 | Cars & Trucks
I have a King Kutter brush hogger and am having trouble getting it connect to the New Holland tractor. The man who connected it for me last year is no longer around and the man I hired could not get it...
You are talking about a three point hitch ... they can be tricky. Might be worth the time to go to the farm supply store in your community and take a look at how it should be hooked up and operated. It is dangerous to operate this device with out some training.
May 03, 2011 | King Kutter Garden
Is the King Kutter ATV SeederSpreader suitable for applying lime? If so what setting shoud be used? Thanks, Doug (Giles County, VA)
Jan 29, 2011 | King Kutter ATV SeederSpreader 350Lb...
How do you remove a pulley from a spindle unit to replace the bolts holding it to the deck.
First remove the nut on top of the pulley using a 1 1/16 in. wrench or socket. Then you will need to pry the pulley of the shaft using two pry bars. A bit of force may be required. It will kind of pop off when it does finally break loose. Be careful not to lose the half moon key that will still be in the slot on the shaft.
Aug 18, 2010 | King Kutter Pull Type Rotary Kutter 72in....
The tiller will not rotate. The PTO shaft on the tractor is spinning but the tiller will not move. The shaft coming out of the top of the tiller will not spin. There was also a burning smell with a...
Sounds as if you might have destroyed the gearbox or cooked the internal clutches or both....nothing to do but disassemble the gearbox to find out...you may have a broken gear tooth or teeth jamming the pinion...the FIX may be more expensive than the cost of a new tiller...call Tractor Supply to see if replacement parts are even available...sorry to be the bearer of such bad news... ;-(
Aug 11, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | King Kutter II Gear Driven Rotary Tiller...
How much gear oil 72'' tiller
Apr 09, 2010 | King Kutter II Gear Driven Rotary Tiller...
My king kutter till will not hold gear oil.
Mar 23, 2009 | King Kutter II Gear Driven Rotary Tiller...
King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P Logo
134 people viewed this question
Top King Kutter Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a King Kutter Tool and Hardware - Other Expert? Answer questions, earn points and help others
