I need software in connect the xerox machine to computer
Hi..
connect cable to pc then install software driver
TQ
SOURCE: my ir3300 xerox machine not print out.please solve thins problem.
How are you trying to print? You need N boot rom. Press Counter Check. Do you see IR3300(IR2200N) or IR3300(IR2200). If you see the N then you should be able to print with it. If not, you can't.
In Service Mode (to get into this press Additional Functions (button with * on it) > 2 then 8 > Additional Functions) go to Copier > Display > Version. What do you see for BOOT-ROM (does it have a N at the end?). For PS/PCL what do you see?
If your BOOT-ROM is N and you don't have a number for PS/PCL then call a technician to install networked system software.
If BOOT-ROM is not N, buy a Network Multi-PDL Kit C1 and get a technician to install it and load N system software.
If BOOT-ROM is N and you have number for PS/PCL check your IP settings. Make sure that DHCP is turned off. Set up your printer using an IP port with the static IP address assigned to the copier.
Use PCL5e or PS drivers, don't use PCL6.
SOURCE: canon ir3300 or 405 better
Definitely go with the 3300 (if you haven't already). It's one of the best B&W copiers Canon has ever produced. The 3300s still sold as refurbs by Canon in the US so parts will be around for them over there for quite a while yet.
