SOURCE: Fossil watch dead
1)Get the battery out again and check for power. 1,5 Volt batteries should be 1,52V - 1,54V and the 3Volt batteries shold be 3,1V - 3,3V in charge.
2)Take the hardened steel needle or watchmakers screwdriver and clean (scrape) both contacts off any visible residue till they are shiny. aaaaaaaUce dust blower to get rid of scrape-offs.
3)Make sure the contacts are touching the corresponding battery side only and not shortcuting the battery.
Do not forget to rate please.
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
SOURCE: Fossil Watch Repair,crystal replacement Fossil TM7221
See SuisseWatchService.com for watch crystal replacement in the USA.
