This probably could be defective Printhead ( black/yellow )
Follow the steps below and it should resolve the issue, if not, you need to replace the K/Y Printhead. You can purchase it from any nearest departmental store like bestbuy or costco or walmart etc or Call HP and order one.
Open the front access door. ( printer must be power on )
Remove the Latch of the Printheads
Remove the Printhead
Clean the Contacts with lint free cloth ( golden contacts or electrical contacts / not the nozzles )
Re-install the Printhead back in its position and close the front access door.
The printer usually goes thru initialization process. or Turn off the printer and turn on.
If you still get the error message, Replace the K/Y Printhead.
Regards,
Ron
// Rate this solution with 4 Thumbs to help us improve the support
SOURCE: The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
SOURCE: Printer: HP OfficejetPro L7680 ALL-IN-ONE immediately
hi!!
try to re-install the driver of your printer
and then try to unhook the cartridge and then
clean up the nozzle used alcohol and cotton buds
and then placed it back the cartridge correctly!!!
SOURCE: The following printhead(s) have a
The printheads are different than the cartridges. Here's a video on replacing printheads on the Officejet Pro L7780. You can order new printheads from the HP website www.suresupply.com.
SOURCE: Our officejet Pro L7650 will not print; the screen
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English),
If you need more help come back.Post / thumbs / testimonial are welcome!
SOURCE: I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
2.
Reset the printer by unplugging the power adapter from the printer (should be
the whole black box on the back of the printer), leave it unplugged for about a
minute then plug it back in.
3. Once the printer is back on, it will ask for
the printhead. Just disregard the message by pressing or CANCEL button on your
printer screen. Do not install the printhead yet.
4. Then, please use this link: http://bit.ly/p705fw to download and run the firmware on your computer. Please make sure that the
USB cable is attached from the printer to the computer while you do this.
5. Once the firmware update is complete, you may reinstall the printhead.
