Hi First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then it means that the control board has gone bad and
should be replaced. Hope this helps...please post back for further assistance. Daniel
color:black;mso-ansi-language:EN-IN;mso-fareast-language:EN-US;mso-bidi-language:
AR-SA">Thanks....To resolve this error try pressing this reset sequence-- Heat Dry -
Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi
Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let
the unit run for 2-3 minutes and then you press the Cancel/Drain button and
allow it to completely drain and reset.
Hi
If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry .
Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button
and allow it to completely drain and reset. If this doesn't work then it's an
issue with the wash pump not pumping the water past the heater efficiently or
due to lack of water to heat. Please make sure that heater is not open
circuited and is heating the water efficiently. You'll have to check the heater
using a multimeter; the meter should read between 3000 to 3300 ohms (Use
multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure
is optimum and fill valve is working fine. Hope this helps... Please post
back if you need more information.
Daniel
We had already checked to be sure nothing was lodged/hung. We had seen on the internet that there was some sequence of buttons to push to clear the control board and were seeking that, but could not get any information on how to clear the control board when the start button was flashing. Sears agreed it exists but wants $ 130 to come diagnose. Still don't know what to do.
