The primer bulb should be attached directly to the carburetor. There will be a plate with 4 screws, once on each corner, which you will have to remove to get the primer bulb off of the carburetor. You can find replacement primer bulbs at PartsBuggy.com.
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
There is a threaded cap on the spool that can get very tight, but a pair of Channel-loc pliers usually does the trick to remove the cap. Getting the string to feed consistently is a trick that I have not figured out how to do...
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
