2000-0142 is an UNREPAIRABLE hard drive failure.
IF you can boot to windows, do so and copy any important data to a CD, DVD or external drive before it completely fails (If system will not boot in normal mode, try safe mode (F8 at boot)
If you cannot boot to windows, then you may be able to get a replacement HDD, install windows and drivers on it, then using a USB HDD adapter, see if you can find your data on the old drive.
Regardless, the only way to fix the computer is to replace the drive, there is no tool that will REPAIR a 200-0142 error on a hard drive, only replacement.
