Microsoft Xbox Console Logo
Posted on Jul 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ethernet cable is connected to the modem and my xbox but its says its not and it wont even let me test my wired connection.ITS NOT LETTING ME CONNECT TO XBOX LIVE EVEN THOUGH EVERTHING IS CORRECTLY SET UP!!
Anonymous
Level 2:
  • Expert 102 Answers
  • Posted on Jul 02, 2011
Anonymous
Expert
Level 2:
Answers
102
Questions
0
Helped
26201
Points
364
What Model of XBOX is this?
If it is not the 360 or the slim it will no longer work on live.
Microsoft phased them out last month.
4helpful
4answers
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Can't connect to Xbox 360
reset it...look at back side of modem.....
and if it not works then contact your isp ...
2helpful
2answers
X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
I'm trying to connect an xbox 360 to the ethernet using a cable modem. We're having trouble. Is this possible? We connected the modem to the cable hook-up and connected the ethernet cable from the modem to...
Make sure your modem or router is compatible with XBOX. I think Microsoft has a lost of working modems and routers. If this is all clear, connect the eth.cable to the modem/router. Power up the modem FIRST then the xbox. All this without any cd/dvd in the tray.
Usually as simple as that...
Xbox live - no connection
hey im having almost same problem, i got a motorola s8vs SURFboard cable modem with a battery in it and my ethernet ccord runs from my modem to my xbox but yet my xbox cant read my ip adress, why is this.. do you know?
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
