WE ARE TRYING TO GET TELEVISON RECEPTIOB BUT WE GET "NO SIGNAL INPUT COMPONENT 5 AND THEN IT POWERS OFF". WE HAVE A PIONEER PDP 425 MX. I HAVE TRIED TO USE ONLY INPUT 4 BUT TV WILL NOT STAY ON LONG ENOUGH
    New Friend:
  • 43 Answers
The reason your tv is powering down is that it is not receiving an input signal on the channel (input). basically you don't have anything plugged in and turned so the tv doesn't see a signal on component 5 so it shuts the tv off. turn on your TV and hit the input button until you get to the input that you are have a device installed on. just make sure the device you are trying to see on the tv is turned on prior to turning on your tv.
If you do not have an and device plugged in (cable or other input device), plug something in to an input and turn the device on so a signal is being sent to the tv and then turn on your tv and change the channel to that input.
if you are locked on input 5, install and turn on a device to that input so the TV registers it as an active input.
Posted on Jul 02, 2011
SOURCE:
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
Feb 05, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Apr 11, 2013 | Televison & Video
What parts probably need replacing on my Pioneer plasma PDP-5010 FD after a home lightening strike?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 03, 2017 | Pioneer PDP-5010FD 50 in. Plasma HDTV
How can I connect a coaxial cable to Pioneer PDP-505CMX 50 in. Plasma Television
If it has a coax fitting on the back connect there. If it does not have (means it is a monitor with no tuner) connect with a/v jacks to the correct input (component?) from a box and select that input to use for watching programs----picture will always be better via rear inputs than coax.
If you have questions press the make a comment button here.
Mar 25, 2012 | Pioneer PDP-505CMX 50 in. Plasma...
PDP-427CMX powers on then the standby blinks 3 times
You could hang it over your bed as a work-around. ;-)
Sep 09, 2008 | Pioneer PDP-427CMX Television
Hdmi input on pioneer pdp-r04u doesn't work. The component cables work, but not the HDMI. The digital audio works.
the r04u comes factory with hdmi DISABLED, hook up your hdmi device, and turn r04u to the hdmi  input (input 1 or input 3)  then:
To activate the HDMI terminal:
1 Press HOME MENU.
2 Press /  to select “Option”, and then press
ENTER.
3 Press /  to select “HDMI Input”, and then press
ENTER.
4 Press /  to select “Setting”, and then press
ENTER.
5 Press /  to select “Enable”, and then press
ENTER.
there you go
Sep 04, 2008 | Televison & Video
Pioneer pdp 503
Hi, my PDP 50XE just cut out, when powered back on the screen powers down and the standby light flashes twice followed by a 5 sec gap.  Anyone got any thoughts? Thanks
Jun 28, 2008 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
339 people viewed this question
Top Televison & Video Experts
Ekse
