Despite it being new, it sounds like either the hose is clogged or to long (no more than 5 feet in length) or is kinked. The other may be, that the hose connection on the dehumidifier is clogged.
After checking the hose for clogs and length and finding nothing. The clog is in the hose connection tubing. To remove the clog do the following.
Turn the unit OFF and unplug it. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though, carefully insert the Zip Tie into the hose connector tubing, Continue to push it in, until you reach a bend in the tubing. You will gingerly have to work the Zip Tie past this bend, until the Zip Tie either bottoms out or you run out of usable Zip Tie. Then pull the Zip Tie out slowly, while rotating (twisting) it. This will dislodge any clogs. As you reach the inserted end, be prepared for some water to follow.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
