1995 Mercury Sable Logo
Posted on Jul 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have 1995 Mercury Sable Ls. The car will not start. When turning the key I get nothing no clicking noise lights dim. We tried to jump the car off with jumper cables and it still does not start. Checked fuses all good. Replaced Battery still won't start. Any suggestions
Mobile Auto Services
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Jul 01, 2011
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
12906
Points
151
Check all wires running to battery. Check the battery ground(black) cable for sure. Make sure it is getting a good ground. If necessary unbolt the ground and clean up with a wire brush or wheel.
  • ROBERT BAKER
    ROBERT BAKER Feb 18, 2014
    it was the ground wire i fixed not the positive wire
My key won't turn to start my car... It's a 92 Sable Mercury.
Try a lubricant.
Mercury Sable key ? Mile High Locksmith â„¢
www.denver-locksmith.net/2013/12/mercury-sable-key-replacement/
Dec 23, 2013 - Mercury Sable keys have changed over the years. ... 1991, 1992, 1993, 1994, or 1995, then your car requires two keys. ... If your Mercury Sable was made in the year 1997, then some of the cars will have a transponder key, and some won't. ...Insert the new key into your ignition switch and turn it to the on .
1helpful
On the 3.0 engine when I start it, it just clicks or the egnine barley turns like the battery is dead. Yet the lights don't dim, tried jumping the car and even switched battery's still wont work.
remove the starter and have it bench checked, Its dragging or is binding in the mount somehow. you can bench check it yourself with a set of jumper cables,, put the positive where the positive wire attaches to your starter, and ground the case with the neg ,, be careful it jumps when you touch the cables on,
1helpful
Tachometer went wacky, overheated, now will not start
Have the battery and cables checked they carode inside the insulation and draw alot but allow very little power through.
2answers
Car wont start
try resetting your computer
I have a 95 mec sable wgn 3.8 and it wont start turn key and nothing happens no sound and the lights dont dim like if bat is weak also radio and dash clock shut off but when back on stilcorrect settings im...
try to check if the starter relay clicking while you start.If no maybe bad connection from ignition key. If the relay clicking maybe the connection to starter or the starter itself is damaged. try to direct the sol. of starter to batt. positive if it kick your starter is good.
1helpful
I HAVE A 1995 ISUZU TROOPER W/105K MILES. DROVE CAR & PARKED IT FOR 2 HRS. TRIED TO START IT WOULDN'T TURN OVER & MADE NO NOISE/CLICK WHEN KEY IS TURNED ON. I THEN CHARGED BATTERY (IT'S GOOD FAIRLY...
Could be one of two things.
1. Your starter motor is no good.
2. If you turn on your lights and try to start the car and they dim to almost black, then you need to check the battery connections.
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
