If your printer has been idle for too long, the tendency is that your cartridge will clog or dry out. Try dipping the printhead in a bowl with warm water+ alcohol solution for 30 seconds. Pat it dry and reinstall and see if it works.
http://www.printerquickfix.blogspot.com/
Hello hol0,
If the printer has not been used the ink cartridge may be dried/clogged. This happens when ink does not flow for long periods of time. The cartridge may be full of ink (therefore, not giving low ink level warnings) but unable to flow due to clogged pathways. Try a new ink cartridge and that should fix your problem!
Hope this helps!
