Question about EliteGroup 848P-A Motherboard
I am using a 848P-A motherboard. I have just installed a SATA hard disk and changed OnChip IDE Device>Onchip Serial ATA to "Enhanced"(intend to use the new SATA drive as a secondary drive) but the system do not seems to recognize the new drive. When I look at my computer the new drive is not shown. What could be wrong? Any help will be much appreciated. Than you. John Yap
    Novelist:
  • 152 Answers
1. Does your new SATA hard drive can be seen in BIOS or POST. if yes 2. Does this new drive shown in "my computer" it should be no or under device manager is should be yes. 3. Use disk management.
To start Disk Management:
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Top or Bottom on the View menu, and then click the view that you want to use.
To create a new partition or logical drive on a basic disk:
  1. In the Disk Management window, complete one of the following procedures, and then continue to step 2:
    • To create a new partition, right-click unallocated space on the basic disk where you want to create the partition, and then click New Partition.
    • To create a new logical drive in an extended partition, right-click free space on an extended partition where you want to create the logical drive, and then click New Logical Drive.
  2. In the New Partition Wizard, click Next.
  3. Click the type of partition that you want to create (either Primary partition, Extended partition, or Logical drive), and then click Next.
  4. Specify the size of the partition in the Partition size in MB box, and then click Next.
  5. Decide whether to manually assign a drive letter, let the system automatically enumerate the drive, or do not assign a drive letter to the new partition or logical drive, and then click Next.
  6. Specify the formatting options you want to use by using one of the following procedures:
    • If you do not want to format the partition, click Do not format this partition, and then click Next.
    • If you want to format the partition, click Format this partition with the following settings, and then complete the following procedure in the Format dialog box:
      1. Type a name for the volume in the Volume label box. This is an optional step.
      2. Click the file system that you want to use in the File system box.
        You can change the disk allocation unit size, and then specify whether to perform a quick format, or enable file and folder compression on NTFS volumes.
      Click Next.
  7. Confirm that the options that selected are correct, and then click Finish.
The new partition or logical drive is created and appears in the appropriate basic disk in the Disk Management window. If you chose to format the volume in step 6, the format process now starts.
To format a partition, logical drive or basic volume:
  1. In the Disk Management window, right-click the partition or logical drive that you want to format (or reformat), and then click Format.
  2. In the Format dialog box, type a name for the volume in the Volume label box. This is an optional step.
  3. Click the file system that you want to use in the File system box. If you want, you can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
  4. Click OK.
  5. Click OK when you are prompted to format the volume. The format process starts.
For further Instructions click the link DISK.
Thanks, looking forward to fix your problem, just give a feedback if this helps.
Posted on Jul 02, 2011
SOURCE:
How to change sata to ata in bios
If you want to install Windows XP or configure a RAID array, you may need to change the SATA type in BIOS. here I will introduce some method of SATA settings in BIOS. SATA HDD(hard disk) has been more porpular because of the hight transferring speed and simple installation. If you want to Install a Windows XP in SATA hard disk. we offen need a floppy disk to save the additional driver of SATA/RAID. but the floppy isn't too easy to find. So we can do another method, modify the SATA type to compatible IDE or ATA mode, etc.
Notes: If your computer has installed some operating systems. Changing SATA types may corrupt your systems or need to be repaired again. But when can I change the SATA type?
1. You are prepairing install a new operating systems, for commonly Windows XP. If Windows 7/Vista will be installed. you need nothing changed in BIOS unless the setting has been modified.
2. Or you want to install a RAID.
I will introduce how to install Windows XP at SATA HDD(hard disk) in the coming chapters, here we need to know how to change the SATA type in BIOS. At first we need to access BIOS, Here is my desktop BIOS, we can find the BIOS is from AWARD software.
201003290718324672.jpgIn my BIOS, the harddisk settings are in the line of integrated peripherals, different BIOS or different OEM menufactures may have different promise. you can try the Advanced BIOS features setting or Integrated peripherals, or system configuration, etc.
Locale to Integrated Peripherals and press enter, you may find the SATA configuration.
201004010308121905.jpgthe above screenshot is the SATA configuration position. There are two items about SATA controller, Onchip SATA controller and Onchip SATA Type, Notes: There may be one or more configurations about SATA, we only need to change the SATA Type. you should not close the SATA controller if you don't know what's will be happened.
Navagete to the Onchip SATA Type and press ENTER, we can find these selections: Native IDE, AHCI, RAID. If you want to install Windows XP, you may need to change to Native IDE(some called ATA) mode, when you finished installation, you can refresh your SATA drivers in Windows XP and change the SATA type to AHCI mode in BIOS again.
If you want to configure a raid array. set to RAID similarity. When finished settings, you should press enter to accept it, and save to CMOS before restart your computer. In my BIOS, I need to exit to the BIOS main menu at first and save it.
when the new status has been saved, you can press CTRL+ALT+DEL to restart your computer, some OEM PCs may need to click the EXIT or Save to CMOS and Exit, the computer will be restart automatically.
Another example screenshot is my DELL notebook BIOS. DELL BIOS is not the same as the desktop BIOS, we can find the SATA operation behind the System Configuration. there are only three selections (Disabled, ATA, AHCI). If you want to install Windows XP, here need to be changed as ATA mode.
201004010308185104.jpg Notes: If you want to install operating systems, you may need to change the boot orderto boot from your CD/DVD drive.
Oct 10, 2013 | Compaq Presario Notebook
What is the correct Integrated Peripherals setting for PATA/SATA with a IDE hard drive on Primary IDE channel as primary system drive, CD Burner on Secondary IDE channel and a SATA DVD Burner on a SATA...
Integrated Peripherals Menu
1) USB Controller -> Enabled
2) USB Device Legacy Support -> Keyboard + Mouse
3) Use the Down Arrow, and highlight ->
On-Chip IDE Configuration. Press the Enter key.
On-Chip ATA(s) Operate Mode - > Native
ATA Configuration -> P-ATA + S-ATA
S-ATA Keep Enabled -> Yes
P-ATA Keep Enabled -> Yes
P-ATA Channel Selection -> Both
CombinedModeOption -> P-ATA 1st Channel
S-ATA Ports Definition -> P0-3rd
Configure S-ATA as RAID -> NO
4) C.S.A Gigabit Ethernet -> Auto
5) Onboard 1394 Device -> Enabled
6) Onboard Promise IDE -> Disabled
7) AC97 Audio -> Enabled
8) Set Super I/O -> Leave Alone
However let's not cut hairs here.
MAIN thing you need to do F-I-R-S-T, is to write down the settings as they are, BEFORE making changes.
In case a mistake is made, you can go back into BIOS Setup - Integrated Peripherals, and change the settings back to the way they were originally.
This way you can at least use the IDE harddrive, and IDE optical drive, with no SATA optical drive.
Then steam under your collar, find someone who knows more, than Ol' Joe.
(Better to have you ********** at me, than leave you with a non-working computer)
Don't forget to Save Changes, or it will be like you have done nothing at all.
(Need the User Manual for that mobo? Post back in a Comment)
Regards,
joecoolvette
Jul 30, 2012 | MSI 865PE-NEO2-LS Motherboard
Dfi-64 tc problems. i just to install xp (before was windows millenium )now each time when xp load appears a message saying that bus ide drivers does not installed but when i run the drivers disc...
when a person goes install windows xp they encounter the problem of not being able to find any hard disk drives installed as if they weren't connected. The hard drive is detected with no problem in the BIOS and also on start up POST, able to boot up Linux Live CDs but the hard drive is just not being detected in Windows setup. Here is the exact error message.
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.This problem is quite a common one and is simply due to the fact that when Windows XP was created, the SATA chipset itself and SATA hard drives weren't available to the masses, so support for it wasn't included in the XP setup process. As most computers within the last decade or so have some form of SATA controller, if you try to install Windows onto a SATA drive, XP won't recognize it because the drivers aren't present on the installation disc, so they need to be loaded manually for the drive to be picked up.
Thankfully there are a few ways to get around this problem and enable Windows XP to be installed onto a SATA hard drive so you can enjoy the extra performance and other functions like hotplug/AHCI etc. Setting the BIOS Correctly
The first and mos obvious method is to change the SATA Mode to IDE in the system BIOS. Most BIOS's for several years have included a fallback mode to enable a SATA drive to behave like an IDE drive, and therefore makes it visible to XP during setup. The problem with this setting is it comes under several different names and can be found in different sections within the BIOS. It depends entirely on the computer or motherboard's make, model and manufacturer to know which setting you have and where it is. If you have a manual, it's certainly worth reading.
The most obvious thing to look for is a setting which can change the SATA controller to IDE or PATA mode, with options such as AHCI -> IDE or SATA/RAID -> IDE etc. Basically any option you come across to reduce the SATA/RAID mode to IDE/PATA should be the correct one. Don't confuse this option with a similar one which will disable the SATA controller completely. Here's some names we found it could be under in a few motherboard manuals we looked at:
Integrated Peripherals > SATA Devices Configuration > SATA Mode > [IDE]
Integrated Peripherals > Serial ATA Function > Base
Storage Configuration > SATA Mode Selection > Emulated PATA Mode
SATA Configuration > SATA Configuration [Enhanced] > Configure SATA as > IDE
Integrated Peripherals > South OnChip PCI Device > SATA Controller > IDE Mode
Using a Floppy Disk
If you're unable to change RAID mode to IDE or disable SATA in the BIOS, then the next option would be to download SATA/RAID drivers from your motherboard manufacturer's website, extract the drivers to a floppy disk and then insert the floppy into your computer during Windows XP installation. This method obviously gets around the problem of XP not having the drivers on the install CD by you providing them manually.
Windows XP setup won't recognize USB flash drives, so you need to have an internal floppy drive available, many USB floppy drives will also work though. As you can see in the image below, it clearly states that the SATA RAID driver is for use on floppy drives. You need to make sure any drivers you download are explicitly designed for putting onto a floppy and not a generic driver, usually the file will be around 1MB or lower which is a good sign it's likely to be the correct driver.
Insert the Windows XP CD and boot it up. You should see a message that says "Press any key to boot from CD..." Simply hit any key and it'll start to boot from CD. Pay attention to the next blue colored windows setup screen. When you see a message that says "Press F6 if you need to install a third party SCSI or RAID driver..." at the bottom, immediately hit the F6 key.
After loading some files, you will come to a screen that says the following:
Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
< none >
* To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use with Windows, including those for which you have a device support disk from a mass storage device manufacturer, press S.
* If you do not have any device support disks from a mass storage device manufacturer, or do not want to specify additional mass storage devices for use with Windows, press ENTER.Make sure the driver floppy is inserted and press S. It will present a list of drivers which it read from the disk earlier. Select the appropriate driver and continue the Windows XP installation. The setup will continue and this time it will recognize the SATA hard disk drive in your PC. This problem is quite common when trying to install Windows XP on newer computers because most if not all are using SATA hard drives. After installing Windows XP, you can easily and automatically install all required device drivers using the DriverPack Solution disc.
If you thought it wasn't possible to use a USB flash drive instead of a floppy drive to load the drivers during the F6 phase, we have a solution that could !!!
Oct 04, 2017 | DFI CA64-TC Via 694T/686B Mainboard...
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
Mar 04, 2010 | PC Chips M955G Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
Msi p4m800pro ide issues
No Boot (system does post) - Hard drives not detected • Check jumper settings on all IDE devices • Verify that IDE controller is configured correctly in the BIOS • Check to make sure that the drive is connected to the correct controller • Make sure drives are configured correctly for RAID • Verify Onchip IDE configuration for ICH5 SATA operation is set correctly • Test drives with different IDE/SATA cables
Dec 19, 2007 | Intel Motherboard
EliteGroup 848P-A Motherboard Logo
87 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
