Samsung LN52B630 52 in. LCD HDTV Logo
Anonymous Posted on Jul 01, 2011
There appears a vertical white bar on the center of my TV screen. The TV is out of warranty and a month and a year old. What could be the problem?
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jul 01, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366036
Points
33650
You may have to try reseating the ribbon cables between the LCD panel and the T-CON board, very delicate works!
Please download or read about troubleshooting T-CON/LCD panel failure mode to see if that is the symptom you are seeing.
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
PDF download: http://www.mediafire.com/?zzjygannjty
LCD panel: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
3helpful
I have an LG 50"
It means you have a panel display driver problem. A part of your display is being triggered wrong.
If you are within warranty period call service center for help.
Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
3helpful
3answers
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
2helpful
2answers
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
36helpful
6answers
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
2answers
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
4helpful
3answers
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Polaroid FLM 2632 HDTV
I hae replaced my polaroid FLM-2632 3 times it is a crappy tv same problem every time do not buy one
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
