Cut up a plastic card like a coffee loyalty card or something that is the same thickness as the sim, and make it the same width as the sim
Before gluing the tip of this card, push it in the slot to engage the release mechanism inside.
Your trying to get the mechanism on the removal cycle where the sim will be closer to coming out.
once that is done put glue on the plastic card tip.
Wipe all excess glue from the flat surfaces. you don't need much glue at all. if you bought strong grade super glue it tends fuse to sim and plastic together. so less is actually more.
let it dry well past the curing time as its better to be safe than sorry, lets face it, the sims not going anywhere and l doubt you need to make an emergency phone call.
then if your plastic card is close to the thickness of the sim card as mine was, it will depress all the sim contacts and come
out with suprisingly little effort. it felt on mine like you should have been able to tap it out in the first place.
