HP Deskjet D2360 InkJet Printer Logo
Posted on Jul 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am printing in red but output is yellow - HP Deskjet D2360 InkJet Printer
Mia Rose Schultz
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2016
Mia Rose Schultz
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
293
Points
It could be out your red and it is fixed on yellow so that is proboly rjght
Susan Fender
Level 3:
Master:
  • Master 397 Answers
  • Posted on Jul 01, 2011
Susan Fender
Master
Level 3:
Master:
Answers
397
Questions
0
Helped
71041
Points
1191
Check the ink levels- it sounds like your Magenta is out- HP deskjets use CMYK to mix the colors- C = Cyan, M= Magenta, Y = yellow, K = intensity (black). Red is usually a blend of Magenta + Yellow- so if you don't have magenta ink in your printer, when you try to print out something in red- it will come out yellow
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
1helpful
Changed color cartridge, but red prints as yellow
The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed.
Printers and Faxes in the Windows Control Panel , then right-click your printer icon and clickProperties . Click Printing Preferences . Click the Services tab, then theService This Device icon.
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Need instructions to hook up dvd
Check Carefully on the Back on the DVD You will see different color RCA plug yellow, Red and white Input and Output The yellow output from your DVD go on the input TV ...Then the red output go in our red TV input Same for the white RCA plug sample to do ...
The output does not much with the color on the screen
This sounds like a board level issue and will need the manufacturer to get nvolved. I would contact the place you purchased it from and tell them it is not funcitoning as per specifications. They will either refund you , swap it over or send it off to for repairs. Check your warranty details as most of these types of printers have replacement warranties.
All the best!
John
3helpful
2answers
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Red ink problem
red is the combination of Yellow and Magenta toner, try printing one of each independently, if either is printing correctly yellow and magenta you should be able to print red. good luck
1helpful
C900 Colur print problems
Print a self made test page in word, a bar of bright yellow, bright cyan, bright magenta (almost pink) and black.
You might find one is completly missing, if so its a faulty toner or maybe the pull strip did not rip out correclty.
k24674
Grand Canyon Tech
Grand Canyon Tech
