Hi
We recently brought a 2nd hand transmission and now to start we have to put it into Low gear then shift it into 2nd, then drive, reverse is fine. if we put it straight into drive it just cuts out. any help much appreciated.
when we put it into drive it goes in to gear then the engine cuts, it feels like its in the wrong gear?Hi
Yes it does feel like its in 2 gears at once and dragging. the original trans was changed because we would put it into drive and it wouldn't move, when it did engage it would slip out, and also losing a lot of trans fluid.Hi
when you say its cuts out the engine miss or the trans slipps .
im trying to see if its a trans or an engine problemwhen you say its cuts out the engine miss or the trans slipps .
You can't post conmments that contain an email address.
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
hi i have a 2004/05 misubishi lancer just recently the neutral light keeps ... Should I just change the fluid and ...
Jan 2, 2014 - Is your automatic transmission giving you trouble or shifting too hard? ... It was a great idea to get your transmission fluid and filter changed and to keep .... I have 2014 chevy traverse, when you down shift and at the end of a gear ...... It mayalso be due to the 3rd gear shift solenoid going bad so that may be ...
May 8, 2004 - 19 posts - 9 authors
Auto Trans not shifting correctly from 2nd to 3rd Under the Hood. ... Become an EliteExplorer. Lithuania. 1999 5.0. Join Date: Jun 2003. Posts: 107 ... When this happens, the transmission will skip to the next gear like you said.
? 3:59
... Doctor, explores the causes of harsh shifting in automatic transmissions. ... Early diagnosis is important to ...
? 3:59 https://www.youtube.com/watch?v=aAoiL4vR8Qw
hi i have a 2004/05 misubishi lancer just recently the neutral light keeps blinking ... (2nd to 1 st gear ).i replaced atf and filter it does the same thing since ? bought ?t 3 ... having is driving with the overdrive on it won't shift when shift into 3rd gear it just ... I have a ls400 and my auto transmission shift hard when I ...
Aug 25, 2005 - 28 posts - 18 authors
My co-workers tell me I am just not shifting into 2nd gear properly, but I am making an effort to make ... When it won't engage in 2nd can you kick it up to 3rd OK & do the other gears engage OK? ... 25th August 2005, 13:05.
Transmission won't shift out of 2nd gear - Honda TRX Forums: Honda ...www.trx450r.org > ... > 450R Performance and Mods. > EngineDec 24, 2012 - Just rebuilt my 05, new crank and piston (it did not blow up). I didn't touch the gears or shift forks except to make sure they spun and were not.Won't shift out of 2nd. [Archive] - Chevy TrailBlazer, TrailBla
check to make sure manual shift linkage not loose disconnected or damaged.check transmission fluid also see if too low, transmission could be slipping lack or low on fluid,if all is good have transmission range sensor checked have vechicle code scan see if any shift pressure solenoid bad before assuming transmission has failed. if you buy second hand car taking a chance buying a lemon, if you just bought the car have honest mechanic check out transmission if bad owner sold car to you didnt tell you transmission bad i get refund find another car.
THERMOSTAT STAYING OPEN CAUSE PCM STAY IN OPEN LOOP WHICH WILL CASE ENGINE RUN POORLY TRANSMISSION SHIFTING LATE.REPLACE THERMOSTAT SEE IF IT HELPS PROBLEM.
Sounds like the shift lever is not coming completely out of 2nd gear. So, by shifting into 1st gear, you recenter the shift lever. You can confirm this by going under the truck and moving the 1st - 2nd lever on the side of the transmission with your hand. If the shifter goes into reverse after you manually recenter the 1-2 lever, then you need to correct the problem that prevents the "normal" recentering of the 1-2 shift lever.
Possibilities are: Bent shift rod; worn shifter; worn shift rod at connection to shift lever on transmission.
Well, if it was low on fluid, and it was driven for a distance, you could of wrecked the interior gears of the tranni or other parts. I'm not a tranni guy but I know if you run a vechile with low tranni fluid you're asking for a new tranni or to have that one rebuilt.
Code 0753 means Transmission 3-4 shift solenoid or transmission relay circuit problem. The PCM (engine computer) is seeing an incorrect input electrically for the gear or speed it should be seeing. You will need to find a qualified transmission shop to diagnose the problem. Possible causes for the trouble code start with worn/dirty fluid, electrical repairs & transmission overhaul.
Hi
Hi
