That's a nice machine, one of the last mechanical Elnas with the discs for extra stitches. Firstly, you need to wind a bobbin, always use Elna swiss metal bobbins, with holes on one side only, slightly dished. Put on top of the bobbin spindle and take the thread from your spool on the spool holders at the back of the machine across to the tension disc on top left, its white bump, thread through the tension then back to the bobbin and pull the tail through a hole in the top of the bobbin. Flick bobbin across to the right against the stop, disengage the clutch by holding the outer flywheel and turning the inner towards you. Now press the foot pedal to start winding a bobbin, holding the thread tail so it starts off. Wind one full coverage of the bobbin so that the starting point is covered, then stop and cut the tail off with scissors. Now continue winding at 3/4 speed until bobbin is full, watch as it winds and give the thread a nudge with your finger so it fills top and bottom as well as in the middle of the bobbin. When it is full, the bobbin spindle will stop winding. Move it to the left, cut the thread and reennage the clutch by holding flywheel and turning the inner the other way. Now install the bobbin and click the thread into the tension device, see image.
Now thread up the top thread by taking the top thread from the spool, through the tension discs, across to the eyelet on top, down to the check spring, back up to the take up lever, then down to the needle catching the thread into the two thread guides enroute.
See this image.
Now thread through the needle front to back, hold the top thread, close the bobbin cover leaving the tail sticking out the top, lower the needle down by turning the flywheel towards you through one cycle and pull the top thread, drawing the bobbin thread up to the top of the needle plate with it. Pull both threads under the pressure foot to the back and your ready to go. Remember, top tension should be on 5 and bottom tension should be on the red 1, don't change it. Brush out the bobbin holder assembly each time you use this machine and add one drop of oil into the middle of the bobbin holder, there may be a red dot or just the indenation. Run the machine for 30 seconds after oiling without thread, slowly to spread the oil through the bobbin mechanism. Standard 130/704H needles, change regularly (6 hours of sewing) and pick right sized needle and type point for the work you are sewing. Good luck with your SU. If you wanted to join, there is a Yahoo group called "Elna Heirlooms" for fellow Swiss Elna owners.
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
check out this
thanks.
how do i thread my machine
Elna SU Air Electronic
