1997 Mercedes-Benz C-Class Logo
Posted on Aug 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 c320 front right signal light issues - 1997 Mercedes-Benz C-Class
  • sofia_99 Sep 13, 2008
    not sure yet.. might be wiring harness or the socket. The usual "subsitute bulb in use" message didn't come up so I suspect it might be the socket. Will know by next week after finally finding a place other then the dealer.
  • Anonymous Mar 26, 2014
    What is the ground problem on 2002 c320 front turn signal?
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Oct 24, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
9979
Points
25
Try to check the fuse at the right fuse box under the bonnect..
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 255 Answers
  • Posted on Aug 24, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
255
Questions
Helped
151540
Points
647
2002 c320 radio and cagarite lighter do not work.
Had the same issue on 2002 c320 . look at the fuse chart ,find out the fuse # that operate the radio and the cigarette lighter , you have three fuse boxes, engine compartment, driver left knee and trunk on left .find the fuse b compairing the char to the box , replace the fuse . DONE
Turn signal wont work on 2002 c320
The trafficator flash can that clicks and flashes the turn indicator lamps maybe faulty or the trafficator fuse is faulty.
To test the flasher press the hazard warning switch on and if the warning lights do not turn on then the fault is the trafficator can or the fuse is faulty.
My turn signal comes on when I brake.
Check the connector for function, this issue sounds like a trailer issue, grounds are a major issue with trailers.
I have a 2002 pontiac aztek. My rear right signal/brake lamp does not work. When i signal left, the front and rear left lights flash normally. When i signal right, the front right light flashes normally...
as for the faster flashing thats as simple as a blown bulb, replace the bulb and see if that fixes the problem, it may fix the lot because the other symptoms you mention are a bad connection, if bulb is fine check the connection isnt loose or corroded over. if it is simply file it back to establish better connectivity,
1helpful
2answers
2002 Chevy Cavalier - one turn signal blinks twice as fast as normal - have already put in a new bulb. What causes the fast blinking?
turn on your 4 way flashers go in front and back of car see witch light is not flashing its blown must replace easy fix good luck CJ
2helpful
2002 Sunfire SE: rear signal light
Turn the signal light on to the right and probe the contacts in the bulb socket with a test light to see if the power is there,your test light should blink,the other contact in the socket is the parking lights and tail light.
if no power at contacts probe the wire it's self where it enters the socket for power.if you have it there the socket is faulty.
2002 ram 1500 single cab ext light issues
sounds like a faulty underhood fuseblock..have seen lighting issues with these components
2helpful
2answers
Hi i have a 2002 chevy camaro and the turn signals will not blink
You need to replace the flasher. I'm not sure where it is located, but I can look it up if you need me too
Right signal and brake light
Looks like the problem is in the turn signal switch. This is a common problem. When the turn signal switch goes bad it will cause problems as mentioned above by you. Replace the turn signal mechanism.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
