Question about ION Audio Vinyl Recording Turntable
When recording i hear the music,but i do not see the audio meters move
    New Friend:
  • 83 Answers
It depends on which program you are sing but alot of times you need to acsess the settings and allow the turn table to be used in the program. so that the codec can be translated into the program
Posted on Jul 01, 2011
SOURCE:
Not recording anymore
After you press the 'record' button the Minidisc unit is still in "pause mode" - you can hear the music and see the meters move, but notice that the time isn't moving until you press "Play" - then it will start recording. Is the time changing when you go to play it back? You might have left the MD in 'pause' perhaps?
Jan 30, 2014 | Sony Minidisc Mini Disc Remote Control...
It's like I listen to music and I can't hear the words. The music sounds bubbly . It weird. I have cloudphones in blue with a mic and remote. Please help
Also be careful of jewelry (heavy watches/rings) in between your Bluetooth headphones and phone. They can often interfere and will result in the condition described. As well try ensuring the headphones are fully charged as lack of power can also result in conditions described
Aug 25, 2013 | Audio Players & Recorders
I record music on Tascam dp2. Why can't I hear my music in all spks. on 5.1 surr. dvd player? I can hear other cds in all 5 spks.
When u record music, its important that the background music be at -7db and the vocals should bounce the level meters to just over 0 db,also if u use a mixing console to add more instruments to the mix, the mixed output of the added content MUST BE NO MORE THAN -7db in order to maintain balanced music output to all channels.
Dec 04, 2012 | Audio Players & Recorders
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
Jun 08, 2017 | Numark ttUSB Turntable
Panasonic dvx100p is not recording audio
You may have switched the audio channels to the xlr inputs 1 & 2. The switches are under the flip out viewfinder try flipping them to the internal mic and see if you get levels. If the audio level nobs are turned down all the way you won't get audio either. Always check before you go out to shoot, record a few seconds of yourself doing an audio check then play it back to see if you hear anything.
Feb 29, 2012 | Audio Players & Recorders
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
Apr 14, 2010 | Lexicon Alpha Personal Recording Studio
The EZ Vinyl/Tape Converter software seems to have caused a conflict in the audio codec. I can hear the music on vinyl as it records, but now I can't hear iTunes or web sounds. All my settings for volume...
It is probably too late to help you, but others might have this problem and we solved the issue by disabling and enabling.
Click on windows button (bottom left hand corner), control panel - sound - Playback tab
You will find that there are a number of different speaker setups in that area. One set will have the light meter moving, but there won't be sound from your speakers. This is because the modern computer is much more like an amp and has the ability to have different speaker combinations and settings. You only use one speaker set-up.
- double click on a speaker option, advanced tab, and test. If there is no sound, then your speakers aren't connected to that port. Move to the next one.
- Once you find the correct speaker setup for your system, then disable the previous setup and ensure this one is enabled. Once the meter bar lights up for the right speaker combo, all sound will work as expected on your computer.
The modern computer is much like a stereo amp now, and you have to tell it which set to use. (For some reason it works well enough, until you start adding stereo components onto your system.)
Jan 01, 2010 | ION Audio iTTUSB Turntable
Not Able to monitor recording
i am not hearing my music that i wont to record
Mar 20, 2009 | Sony Acid Music Studio 7 Full Version for...
ION Audio Vinyl Recording Turntable Logo
62 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Anthony
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
