Televison & Video Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The tv has shut off, led light is also off. have tried unplugging and leaving unplugged for 24 hours, and trying to power up again. there is no light visible, and there is no response when using any functions on the tv, or the remote control. is this a power source problem, or fuse? is it something i can fix? i do not have an extended warranty and purchased the unit just over a year ago.
Steve Allison
Level 3:
  • Westinghouse Master 5,569 Answers
  • Posted on Jun 30, 2011
Steve Allison
Westinghouse Master
Level 3:
Answers
5569
Questions
Helped
2000721
Points
16452
There are at least two power supplies in every modern set and a possible third in many. One is on all the time, using a small amount of power so the set can respond to your remote control and this one rarely fails. In most sets, it also supplies enough power to use the LED power indicator to blink an error message in a coded sequence. The main power supply is the most common failure but normally the 'always on' supply still works to give a blinking indication that some failure has occurred.
It's very uncommon to have all supplies fail so this is kind of an indication that a line fuse has failed which would disable all and any supplies.
Before digging into the set, if you don't own a multimeter to check the AC outlet, I would take another appliance of some kind and make sure that it gets power from the receptacle you use for the TV. That outlet may be on a line protected with a GFI (Ground Fault Interrupter) that has tripped due to some short-term fault. Also check the circuit breaker for that circuit to see if it has an integrated GFI which has become quite common.
Once you are certain that AC is present at that outlet, remove the back cover of the set and follow the AC line inside to find the first circuit board it goes to. It isn't real common anymore that fuses are in a holder that makes replacement easy so it may be the type soldered to a board with other components.
Unless it is an indicating type of fuse, it may be tough to identify it but the first fuse will normally have a designation printed near it such as 'F1.' If soldered, you would need a soldering iron to replace it and I wouldn't do this before checking the fuse with a multimeter on the lowest Ohms range, typically 200 Ohms full scale. On-board fuses can be in a small cylindrical case oriented vertically with two pins near each other, tubular case mounted parallel to the board with leads on opposite ends and will look a lot like resistors except won't have colored rings on them.
You can buy such a (digital) meter for under $20 (don't spend more) and even much less on line. They will have multiple AC, DC, DC current and Ohms ranges minimum, and some meters will have an additional function for continuity and a separate jack for measuring up to 10 Amperes. They can be bought at Radio Shack, auto parts stores and on line.
I changed panel type in service menu now my tv comes on and does nothing. Ive tried resetting by unplugging. Any button combos ive tried have done nothing. No manual and no info to be found.
How long have you unplugged it for most TV's have a battery back up which you will have to wait for it to power down after unplugging could take up to 24 hours they do this to keep settings in case of a power cut
Sony bravia 65 inch won't turn off
There is one main thing you need to do before any thing you need to unplug the Tv leave off for 24 hours not plugged in do not temp to plug it in then after 24 hours off you need to plug in do not try the remote or press any buttons ok at all just plug in and leave it for 24 hours plugged in then you can unplug the Tv for 30 mins then plug back in and try to use the remote or press the buttons if it still don't work then the power board might be the problem but get back to me afthe 2 days ok to see how you got on
2answers
Why wont the flashing red light go away and switch on my 32 inch led hisense tv
It could be your remote control batteries are dead? Try to manually depress on/off switch on TV.
No power
unplug the wii from the power source then unplug the power source from the wall, wait 30 minutes and try again, if this doesent work leave unplugged for 24 hours.
Model DP26649 No pic no sound no warning. Shut off last night and dead today. Will be 2 yrs old in August.
Now the tv it is completely dead no LED power light indication is on at all or the tv power LED light indication blinking too?Check the power source?Tries tv unplug,replug it back about an hour later for the tv do a resetting itself back to the factory setting,tv should be working again.If not the tv power supply board it is dead,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
1helpful
Philips 26PF5521d LCD TV turns on screen lights for a few seconds then turns off leaving green led flashing Any help apreciated
Tries unplug,replug the tv back like an hour later.Now,the tv is resetting itself back to the factory setting.The tv now,should work again.Not,than the power supply board is the cause.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I dont have a remote for my tv and it wont turn on manually the led light blinks 9 times and stops and starts again what should i do?
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
2answers
TV won't turn on
read from other forum. wouldn't hurt to try, unplug the power for 2 days and plug back in again to see if it will turn on.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
