Depending on the compressor you might have a bad inlet or outlet valve. some have reed valves and also spring loaded disc valves. you could try un hooking head line to tank and put your finger or a peice of thin wood over the line ande see if you have pressure coming out of the line. if not, could b e valves or unloader, or belt slipping from motor to compressor pulley .
