Frigidaire FAH085N1T Air Conditioner Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i installed my a/c unit it said to remove all internal packaging and had no pictures. i removed the styrofoam and my unit is not even cooling the room now.I cant afford to be out 400.00 and need to know what i can do!
  • Electrolux
    Electrolux Jul 06, 2011
    Do you hear the compressor turning on? Do you notice the fan blowing correctly or to what you think it should?
Anonymous
Level 2:
Sergeant:
  • Expert 229 Answers
  • Posted on Jun 30, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
229
Questions
Helped
48016
Points
660
Did you just buy the unit?
Frigidaire model fftr1835vs styrofoam inside filter housing unit. Should it be there?
Not 100%certain to what styrofoam you are referring to but there is definitely styrofoam components inside the machine. The entire drain pan is made of styrofoam, I would not touch it.
How to remove packaging
Based on personal experience, I can say that you need to remove all the cardboard and plastic wrap covering the front, back and various parts inside the refrigerator. Care must be taken to ensure that insulation, which helps the operation of the unit, intended to be part of the design is not removed. If you have a question about some specific insulation (generally styrofoam) then it might be best to call the help line for the manufacturer - they can check with technical experts on that model to determine whether it is needed or not. The primary reason for removing cardboard and wrap is to be sure that all of the necessary ventilation for the unit to operate without overheating is clear.
How to replace window air conditioner fan motor. Difficult to get at motor shaft on room side of AC to remove fan clip and thus remove motor without destroying styrofoam insulation. Even tougher to...
Most of the time I go in from the top of unit with pkiers to remove clip. Once the clip is loose. Hold the shaft with channel locks and the fan should spin. Russ
Removed Styrofoam from A/C
Internal packagings, means in the box-- kits,--brackets--& foam packaging to prevent moving around during shipping or transportations ,and not the unit itself.
1helpful
4answers
I makes a very loud noise
Had same problem with Ge AC. Unplug take out of window and remove all cover screws. Pull up on cover and pull cover off ac, Remove front cover as well there are a couple screws in the front. When looking at front of ac, hit the Styrofoam housing towards your left (towards control panel). Spin fan blade to make sure that it is clear. Plug in to double check. I put a couple quarters between the styrofoam and the metal housing, so it would not slide back. Also tape the styrofoam between the seams this helps with better cooling. Use some good tape nothing cheap. I used black duck tape. It took about 20 mins. The hardest part is re installing the AC.
6helpful
2answers
Frigidaire Air Conditioner - FAC102P1A Compact II th
I spoke with the Frigaire support line 706 374-4432. They said that the large piece of styrofoam, that extends from side to side and nearly top to bottom, is part of the unit. It should not be removed.
2answers
Styrofoam inside
you may open and remove foam not included in unit , be sure return make align everything.
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
