SOURCE: how do you fold down
the steps are numbered 123 on the stroller. press the big round button numbered 1 on the right side (i think), which is located where the handle meets the main part of the stroller. Press the big round button numbered 2 on the other side. After you press button 2, you should be able to fold the handles (both of them together) forward, swinging the handlebars out in an arc until they're nearly touching the front wheel, on the ground. Now, step 3 is the difficult one--you've got to release the catch numbered 3 (underneath the seat, directly beneath where the baby's bottom goes) and then slide the ring forward, along the rod underneath the seat, toward the front wheel. If you can get it going, the rest will happen very smoothly, and the stroller will fold very compactly. It's difficult to describe, but once you get it, it's a cinch after a little practice. Good luck!
SOURCE: my buggy is a quinny zapp i dont know how to fold
First make sure the brake is on. There are two round Grey buttons, one on either side of the frame (about halfway down) they should have a small red triangular numbered sticker above them (1 & 2) Stand behind the pushchair where the handles are and press the left one in (that's number 1) and gently fold the frame a bit but not too much! Do the same with the right one (number 2) when the frame starts to fold in bend the bar down that sits between the handles and place your foot on the Grey pedal located at the bottom of the frame in between the brakes (number 3) and slide it towards the front of the pushchair, as you do this the whole frame should close up.
SOURCE: How do I fold/unfold Zapp?
Thanks for writing to Fixya.
Please find the link below for a video demo for the Stroller.
http://www.squidoo.com/quinnyzapp#module65352271
Thanks
SOURCE: i have a quinny zapp
Sometimes a piece of fabric gets stuck or something else...It might help to push the frame a bit more together before pushing the buttons.
Did you mention the buttons being numbered?Follow the number you can read. The ones you can read when it's folded are in a different order than what you can read when it's not.
Normally when you follow the numbers you just have to push each button once, then pull back both handles to unfold the back. Then pull the "grip" underneath the cetral tube untill it clicks.Then straighten the hinged bar between the handles.
Hope this helps!
Hi narie656, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Would need to know what country you're in, and exactly what model Zapp you have?
(Original, Zapp Xtra or Zapp Xtra 2)
