SOURCE: smelly washing machine!
The black cover you have removed should be the only "filter"/trap in the drainage system inside the machine. The eggy smell you described has to be caused by one of 4 things; 1. Smell coming back through the drain, indicating that there is no water trap - easiest way to check this would be to disconnect the drain hose from the wall, smell the drain and see if it is the same smell or not. if so, install a water trap, or arrange the drain hose in a loop to form one. 2. Decomposing organic matter in the wet system. There could have been something in a pocket or that accidentally got in with the laundry that has somehow got stuck somewhere - possibly in a filter but also limescale can trap dirt in the system and various items can get stuck in all sorts of places. This can be solved nearly always by running through the cleaning procedure described on this link; http://ezinearticles.com/?Cleaning-Your-Washing-Machine&id=109993 if it doesnt work the first time - try it again - sometimes it can take a couple of tries but nearly always works great. there are also stronger chemicals than vinegar that you can use to clean the machine with, (but they should only be used in extreme circumstances as other components can be degraded) white vinegar is usually all you need. To remove the vinegar smell afterwards if necessary - put a teaspoon or two of baking soda through the machine on an empty hot wash. 3. Decomposing organic matter in the dryer outlet duct (or possibly in the lint filter area, but unlikely, also possibly under the machine up inside where the workings are) - rodents and insects and moss and funghi etc all love the warm moist air that comes out of the dryer and they always can find a way into the duct - something dies or poops in the duct and the smell can be unbearable - easy way to check this is to look in the duct if you can, and see if the smell gets worse if you have the dryer on. Clean the duct out with mild dilute bleach if this is the problem. 4. Some liquid detergents cause a build up slowly in the system that smell quite sewage-like (possibly some powders too, but not so common) - try cleaning out the machine and switching to a different detergent to check if that's the case. Unfortunately the Bosch website manuals page is down today - they will have a manual for your model almost certainly - it is an excellent site; http://www.boschappliances.com/site_tools/documents.cfm try again in a day or two - and you should get a user guide downloaded. An overheating motor is unlikely to be the cause of this smell, "eggy" is not associated with motor or electronic overheating problems. Hope this helps, if you cant cure the smell with these tips, then unfortunately the machine has to be taken apart and the offending item cleaned out - if you fancy trying this yourself then please ask again and we could talk you through it, Good luck :)
SOURCE: Bosch WFL2060. Can't unscrew the cover to clean out blockage.
I had the same problem.First, open the cover panel at the bottom right of the front of the washer (push the release down at the top of the panel (about 4 inches off the floor). Next, drain the water into a shallow pan by pulling out the black tube (to the left of the big round pump filter plug) and pull off the cap on the end of it. Next, (sometimes the hard part) unscrew the pump filter plug. If it's stuck you may want a tool. I ended up using a pair of pliers on this plug. You may want to use a pair of vice-grip locking pliers and put a piece of thick metal on each side so you don't break the plug (about 1/2" X 2" plate). MAKE SURE YOU TURN COUNTER CLOCKWISE! Wiggle it back and forth as you may have a wire or hairpin half in and half out of the pump filter area. It takes 2 full turns to get past the threads in order for the plug to come out. I had an underwire from a bra that gave me the worst problem. I worked on it for almost an hour. I have found change, jewelry, hairpins, BBs, small rocks, and a 4" long underwire from a bra. Please rate my solution if this gives you enough details to complete your task. THANKS!!
SOURCE: Bosch Classixx 1000: Won't drain
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by
the machine during the softening cycle, so that the machine does not
completely fill the softening tray; only when the softening tray is
filled beyond the 'max' mark does the siphon action works. A partially
filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the
softening action is that the water inlet of the machine is partial
blocked (you can try to fix that) but it is simpler to just added more
water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every
time (after adding the softener to the softener tray of course) is to
top up the softener tray with extra water, top it up to the 'max level'
line (keep a bottle of water by the machine). That way, even if only a
little water is added to the softener tray during the softening cycle
by the machine it is enough to trigger the siphon action and the tray
will empty!
Works for me every time, and no need to remove any parts - I used to
take the tray out, clean it, scrub the outlet holes that fill the tray
etc, but they used to gum up again quite quickly!
Hope that helps
SOURCE: Bad smell in Bosch nexxt WFMC3200 washer
Check where water might be building up at door if front loader. Mildew will start. On some units free kits were given to repair standing water issues. You can run a small load with bleach (without clothes) to wash away any mildew, however, if there is a drain issue, bleach can also be held back and later affect clothes. If you have mildew in hoses, I would question how water is not being pumped out, is the drain hose higher then the unit itself?
Testimonial: "Thanks for the pointer. The drain is a sink feed and its outlet is below the washer top where the pump pushes the water. I really think that the check valve was stuck open and allowed the dirty water to flow back into the drum."
SOURCE: nasty mildew smell from washing machine
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
