Thank you k_akima, I really appreciate your help in locating a download of a manual for my Canon 580 ex flashgun. Best wishes, Stan.Thank you k_akima, I really appreciate your help in locating a download of a manual for my Canon 580 ex flashgun.
Best wishes,
Stan.
You can't post conmments that contain an email address.
The Wansen RF-602 for canon can.
Check what Wansen has to say. Eventually use Google to find what test sites like DPreview has to say about triggers. Products Flash Trigger WanSen Photography
The manuals for the 580EX and the 430EX say the following under "Reverting to nnnEX Default Settings": "When nnnEX is attached to an EOS camera equipped with a button, you can press it to revert the xxxEX's settings (except custom settings) to the default.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless Flash mode - Manual flash Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
If the formatting gets screwed up, the links are: http://www.usa.canon.com/cusa/professional/ products/professional_cameras/ digital_slr_cameras/eos_1d_mark_iii#BrochuresAndManuals
Hi, the flash in question will not work in TTL mode even though it has contacts on the bottom that may indicate that it could...... so it will work in auto or manual mode but not adjust itself. All adjustments will have to be made manually.
Hi Bruce,
You have the latest cameras and they will work with ETTL II with Canon 430EX/550EX/580EX and 580EX II. Earlier models use ETTL and films use TTL.
Hope they are helpful.
[email protected]
You can get the proper manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=316&modelid=14998
