Hi,for DVD playback only, BD untested. Tested with a Code 1 DVD on a Swiss unit after being unlocked with the OneForAll URC-7950.
Full procedure for the OneForAll URC-7950 remote is as follows:
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until the red led flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until the red led flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until the red led flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
3. Put the player back into standby with the Sony remote.
4. Next time you turn on the player it will be region free for DVD playback.
Please use this guide at your own risk.
Hope it helped..
SOURCE: Could Anyone Tell Me, How To Unlock Region Free A BDP-S300 Player??
http://www.stegen.com/product_info.php/products_id/1019?osCsid=daccaf0338a597dd1985e0ad70ac277a
SOURCE: LG Blu-Ray BD-370 unlock codes
To set DVD Region to “0”, download file “6000.zip” (often also called “LG6000.zip”) from here:
http://www.multi-region.net/_media/6000.zip
Save the file and then unzip and extract it to your hard drive.
Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, “closed” CD-ROM).
Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done!
SOURCE: Can the LG BD370 be made region free?
Good news! It can be made to be region free. However it's not as simple as entering a code on the remote. You'll need to update the firmware on the player's chip. Read this forum to see how to do it. It's not hard but will take a little time to do,
Testimonial: "Burned the CD per the instructions in the June 5, 2009 post using Nero 9 and away we go, region free out of the gate."
SOURCE: Region code unlocking of Marantz BD 7003 Blu Ray Player.
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_cb87u
SOURCE: i have a Samsung BD-C7500
The details below only work for the DVD Region (dependant on your Firmware) and not the Blu Ray.
1. Ensure that there is no disk in the tray.
2. Switch the player on.
3. Wait until the main menu page appears and the player stops doing anything.
4. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller - and enter the players region code from below on the number pad.
5. The the players region code should appear at the top left corner of the screen.
6. Quickly enter a "9" to make the player region free. (Just try pressing 9 on the remote controller until you see 9 appear in the upper left corner of your TV screen.)
7. Open and close the disc tray. Power down and power up again.
All region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
6 - 2 4 4 6 2
ok that all good if you have that remote but i dont i have the original remote and i have a harmony 525 remote so do you have any other info that mite help thanks.
