Be sure if you computer and the installer is the same as 32 or 64 bit.. check your computer and your installer.... be sure you have updated version of your motherboard..
The problem is the file format of the install DVD, older MSI BIOS's have trouble reading the disc unless it is created with a different boot image than what MS supplies.
Solution is here:
http://www.unawave.de/windows-7-tipps/code5-error.html?lang=EN
SOURCE: i need driver usb 2.0 for my mother board MSI
Windows should find and install the latest themselves, try letting it do a driver search online to find the latest.
Otherwise get from the manufacturer. Try here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=600
The chipset drivers should do it.
Testimonial: "many thanks for your solutions.. regards, abet"
