The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem.
SOURCE: Error 50
The "E50" error code indicates formatting a storage card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another storage card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other storage card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the storage card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem.
