Hi, well you would be able to get that spare part directly from the manufacturer,however FIRST you will need a service manual, to be able to get that parts number so you can identify the part and order it.
I also think that the "Door" may actually be part of the case? and as such will not be sold as a separate item, you will have to check?
http://connect.in.com/fujifilm-digital-camera-repair/images--fujifilm-finepix-s2500hd-s2600hd-s2700hd-service-manual-repair-1-895088995369.html
http://www.nodevice.com/manual/newmans/fujifilm_usa/ZM00377-102pdf/get49684.html
Above are links for a service manual.
To my mind though the cheapest and least hassle way would be to take it into a camera repair shop, and simply get a "Quote", then at least you would know what you are up for cost wise,or alternatively, ask at that local camera repair shop, to get you the "Door" or case half, as the case may be?
You may like to try a "Heath Robinson" repair and this can often be affected by using stiff cardboard and "Gaffer Tape", and cut the card, so that it securely fits into the door gap, now Tin Foil folded and glued on one side, this can be used across the inside end of this to make the batteries connect, use the tape to hold it in place. It may not be pretty but it will work, well at least until you get a proper fix?
Unfortunaltely the same type door will be availabel ONLY with the Fuji service center. The other option is to source or get one from a discarded set- that was scrapped for a different failure.
In fact if you can try to get this from any camera service centers or from the Fuji support.
If the door can be glued back then you can reinforce the door with a steel plate and use super glue to make it tough.
Once this is done then the door can be hooked and adjusted to latch.
Welcome to Fixya
I dont think the battery door part is not available or sold separately in the market. Only Fuji has this part in their repair department. You may try to contact Fuji part store regarding this at 1 -866-289-3854.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I CALLED FUJI BEFORE I DID THIS SITE THEY QUIT MAKING IT 2 YRS AGO AND HAVE NO STOCK NOR CAN THEY TELL ME IF ANY OF THERE DISTRIBITERS HAVE IT THANKS ANYWAY
I'M LOOKING FOR A BATTERY DOOR FOR A CAMERA THAT IS OUT OF MAKING 2 YRS AGO A FUJIFILM 2006ZOOM I DID CALL THE CO . AND THEY ORE OUT OF STOCK ALONG TIME AGO
WHAT I HAVE READ I'VE ALSO SUGGESTED BEFORE I READ THIS POSTING . IF SOME ONE HAS A OLD CAMERA LET ME KNOW . AND IF I RECALL SUPER GLUE DOESN'T WORK I HAD TO GET A DIFFERENT GLUE FOR A PIN TIP ON ONE PART THIS I'VE DONE THE GLUING ETC. AND TO PUT A PC. OF STEEL ? ON THE OUT SIDE ? ON THE INSIDE THAT I DON'T THINK WILL WORK . GET ME A DOOR IS MY BEST ROUTE GET ANOTHER EXPERT
I CALLED FUJI FIRST BEFORE I FOUND THIS SITE
I HAVE THE BOX THE CAMERA EVERYTHING IT CAME IN WITH ALL THE PAPERS INCLUDING ALL THE MANUALS AND THE DOOR PART IS NOTED AS PART #15 WITH NO MENTION OF WHERE TO GET JUST A DOOR OR THE CASE WHOLE I EVEN HAVE THE RECEIPT FROM WHEN I BOUGHT IT BUT I STILL NEED THE DOOR KEEP LOOKING THE MANUAL SHOWS OTHER COUNTRIES WOULD YOU LIKE TO LOOK FOR ME ? I'LL PAY YOU TO FIND IT BUT ONLY AFTER YOU HAVE IT FOR ME AS I DID PAY A YOUNG MAN THAT I FELT SORRY FOR HIS CONDITION AND GAVE HIM UP FRONT ONLY TO FIND I WAS STRUNG ALONG FOR MOS. WITH STORIES HE SAID THE DOG CHEWED IT ETC.
