Televison & Video Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony kdf-60xs955 blinks red six times and the screen never turns on . I didd replace the lamp and the problem still exist
Anonymous
Level 3:
  • Master 934 Answers
  • Posted on Jun 30, 2011
Anonymous
Master
Level 3:
Answers
934
Questions
Helped
504502
Points
2229
Test the thermal fuse on top of the lamp housing for open it's likely the cause... Can't remember the part number off the top of my head but that shouldn't be difficult to find.
2helpful
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
5helpful
The green light blinked over 30 times and now the lamp light flashing red consistantly with a wierd sound still black screen on my kdf-60xs955 sony tv
Once your television starts blinking the green light, then it means there is a problem inside the unit.
the problem simply is a bad lamp that is why you are having a black screen.
The solution is simply for you to replace the lamp of the television with a new one. To replace this, you will have to unscrew the television open and try to remove the old lamp and fix in a new one. It is very easy.
If you are still having the blinking light, then it means it is not only the lamp that is faulty, there also is a bad capacitor on either the main panel or the power panel of the television that needs to be replaced.
Once the bad capacitor is replaced, your television will be in good condition once again.
Take care and good luck
4helpful
3answers
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
The on lcd little light blink six time
The standby light blinks to indicate problems with the TV. Six blinks indicates an internal problem, I suspect with the lamp. I recommend contacting a Sony repair shop to vacuum out the TV and replace the lamp. Installing it yourself has no bulb warranty and you cannot vacuum it out without taking it apart. Lamps are $250+ each...
My sony grand wega kdf-60XS955 dont turn on
Power suppply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Sony kdf 55xs955
Low B error protect is what 6 blinks means on the LA-3 chassis
3answers
Sony Grand WEGA KDF-60XS955
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
