The problem of the coffee maker is simply from the thermostat regulator. It is bad and need to be replaced. To fix this is quite expensive, and will require a professional touch from an expert that will be able to carefully disassemble am reassemble the components for you as the parts are quite sensitive to deal with.
There is no reset switch for this coffee maker, you just have to replace the thermostat before it can start working fine once again.
Hope this was helpful.
Goodluck
Elect_Comp
Hi, you can go here for trouble shooting and other help http://www.coffeeespressopro.com/bunn-home-coffee-maker-troubleshooting.html
where can I have this product fixed and/or where can I get parts and directions to fix the product?
