Washing Machines Logo
Anonymous Posted on Jun 29, 2011
How i unlock a bosch classicxx washing machine possible child lock.
  • 1 more comment
  • Anonymous Jun 29, 2011
    No that did not work any other ideas.
    I turned the dial until the key sign stop flashing and when i got to where the key sign was continious i then held the start/pause pause button for 5 seconds. then i could select an other program. That seemed to do the job. Thanks Man
    Thanks for that. job done.
Wale Sarumi KomputerSolution
Level 3:
  • Washing Mach... Master 6,993 Answers
  • Posted on Jun 29, 2011
Level 3:
Answers
6993
Questions
Helped
1701280
Points
1261
press and hold the start/pause button for about 5 seconds then it should take the child lock of and should be back to normal operation.
Let me know if that doesn't work for further directions.
Good luck.
If a bosch washing machine is indicating 0 on the display panel.how do we resolve the problem
Unknown what model it is - you can use the comment menu to give more information about your problem.
Possibly a child lock was set according to the Bosch WAE Range Washing Machine link below:
https://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3308-bosch-wae-range-washing-machine-fault-codes
How to unlock a Bosch classic 6 1400 express washing machine ?
The key symbol indicates child lock has been set.
Press and hold the start button until the key symbol goes out.
You should then be able to use the appliance.
How to unlock child lock on bosch lgoxx8
On your user interface well be a icon of a little lock. Some times it will show linking to one or two buttons. Holding them for 5 to 8 seconds will unlock the unit. It's the same process to turn lock on.
My bosch frontloading washing machine when turned on there is flashing of spin and pause/off butons. we can't turn on the washing machine can you please tell me what the problem might be
Try pressing these buttons for 5 seconds, it will unlock.
OR
Press the "menu" button until you see"CHILD LOCK: ON" appear in the display. (if nothing is pressed within 10 seconds following this the menu will close and it will default to program in the display)
Once you see what I just mentioned in the display press the "select" button until"CHILD LOCK : OFF" appears in the display.
Finally by pressing the"start/pause" button the key symbol should disappear confirming you have successfully unlocked..
Pl click if helped.
2answers
Error message CL avantixx 7 washing machine
CL indicates child lock has been activated. to deactivate it you need to press and holding the start button for 5 seconds.
45helpful
2answers
Top Washing Machines Experts
john h
