Michael Kors MK5057 Wrist Watch for Men Logo
Posted on Sep 15, 2017
I just purchased a women's mk 5057 chronograph watch 2 days ago. I believe I set the time properly and according to the manual however it continuously slows down. Each hour it managed to become 7 minutes behind. I understand that watches need servicing however this is a brand new watch. Could I have done something wrong regarding the 3 dials while setting it up?
3 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 21, 2008
SOURCE: how to set a Honora chronograph watch
You have to upload here all details of the watch: model, ref. number. Movement number and good pic would be very helpfull.
Anonymous
  • 1622 Answers
  • Posted on Mar 13, 2011
SOURCE: I want informations about the
Hi, you can use the Google link below for more information about the watch....
google.com/products/catalog?hl=en&q=White+Watch+MK5145&bav=on.2,or.r_gc.r_pw.&um=1&ie=UTF-8&cid=10356009341512532079&sa=X&ei=sep8TdGzIseJ0QGuzbTtAw&ved=0CCgQ8wIwAg#
Thanks for using fixya....
ansel_albert
Ansel Alberto
  • 248 Answers
  • Posted on Jul 09, 2011
SOURCE: How do you set the
You only have to pull the crown of your watch to its third position ( to set the time) so that if you turn it until it reaches 2am or 3 am the day moves and you have to continue it until you reach the exact day of the week. Then, you don't have to set the 24 hour on the watch because the time remains the same on with the time on your watch. observe it. I hope that i had solve your problem.
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
How do I set alarm on Armstrong 45/7041 watch? Did not come with instructions
A= reset
B= Mode
C= ST/STP
D= Light  (edl)
•SETTING TIME AND CALENDAR
1.For time telling mode, press 'B' three times. The seconds should start to flash. Press 'C' to zero out the seconds.
2. Press 'A' minutes will flash, press 'C' to set the minutes.(holding down C will advance the digits faster)
3. Press 'A' hours will flash, press 'C' to set hour.
4.Press 'A' date will flash, press 'C' to set the date.
5.Press 'A' month will flash, press 'C' to set month.
6.press 'A' The day of the week flashes, press 'C' to set day of the week.
7.Press 'B' to finish and it will return to the time.
IF ANYMORE QUESTIONS ABOUT SET FEATURES SUCH AS 'STOPWATCH, SPLIT TIME, SETTING 24 HOUR ALARM, ACTIVATING ALARM, OR SNOOZING THE ALARM'. FEEL FREE TO CONTACT ME @ [email protected] WITH 'ARMITRON WATCH' IN SUBJECT BAR AND I WILL SEND YOU PICS OF THE MANUAL.
-Savannah:)
109helpful
How do I set the date on Michael Kors chronograph watch? I thought it was set, but after February the date is 3 days behind.
I just set mine.....the stem has to be barely pulled out, there are two stem setting but the first is very easy to miss. Once you barely have it out turn and you will see the date change.
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
4helpful
How do you set the correct day on a Invicta 5377
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals. Rate me, please.
6helpful
2answers
Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
1helpful
Need manual for manual+Citizen Eco-Drive Women's Riva Chronograph Watch #FB1024-51d so I can set the time on it
Go to this site and download manual:
http://www.citizenwatch.com/COA/English/find.asp
Do not forget to rate, please.
2helpful
How to set a Honora chronograph watch
2helpful
3answers
Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Top Michael Kors Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
