LG G4015 Cellular Phone Logo
Posted on Jun 29, 2011
Unlocking LG modelG4015 for use with any SIM - LG G4015 Cellular Phone
4helpful
Lg fortune asking for sim network unlock pin on start up why?
You needs this when you are switching your sim card for change your Cricket network or visiting abroad. You can get your Cricket Lg Fortune unlocked by hassle-free procedure in a competitive price online at your door step!!! Just order it online & relax at your home, they e-mailed you once it done.
For Lg Fortune Unlocking procedure Please visit at
Get it from https://24x7unlockcodes.com/product/cricket-lg-fortune-unlock-code
Best lg sim network unlock pin provider : 24x7UnlockCode Network Unlock Code IMEI Unlock Code Unlock Code
2answers
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
3helpful
3answers
Unlock security cod
sim-unlock.net - Unlock by code Your LG GM200 - How to enter code in LG GM200 ? To enter ... Sim-unlock.net is a fully automatic system to assist in unlocking mobile phones. ... Unlocking method to unlock LG GM200 is absolutely secure. sim-unlock.net/simlock/LG/GM200/
Have just been into this site - all types of phone and how to unlock - hope this will help
4helpful
2answers
I bought a unlock code for my lg gt365 neon and i put a tracfone sim card in it and it says emergency calls only how do i fix it so i can use a tracfone sim card.
First you need to unlock your phone before you put tracfone sim card on that phone. Make sure you have appropriate LG neon GT365 unlock code example : if your old sim card using t-mobile you must use t-mobile unlock code for your phone not tracfone. You can get lg unlock code from online seller with lower price and quick turnaround.
3answers
How to unlock the lg xemon (instructions)?
You can Unlock the LG XENON GR500 model Phone using the Unlock code,You can get the Unlock code and instructions from here
Classicunlocking.com and Unlock it from Network Lock....
LG GR500 Xenon Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your LG GR500 Xenon mobile phones. If you enter over a certain amount of wrong unlock codes on your LG GR500 Xenon mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
5helpful
5answers
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
8helpful
3answers
How do i unlock an lg gw300 for free. i need to be able to use any sim in my phone
http://forum.gsmhosting.com/vbb/archive/t-837167.html
Go to this above website they will show you what to do to unlock your phone.
Extract below.
Unlock LG Viewty GW300
1. Power on your LG Viewty GW300 with the original SIM card in.
2. Enter 2945#*700#
3. A menu will pop up, select SIM Unlock.
4. Enter your unlock code and hit OK.
5. Your LG Viewty GW300 may automatically reboot and should now be unlocked! seanjay28
2answers
Need to Unlock LG SHINE CU720 from ATT
fastunlocking.blogspot.com try this service, very fast and trust.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
