Samsung Galaxy Tab Tablet PC Logo
Posted on Jun 28, 2011
How do i turn on wi fi for my tablet? - Samsung Galaxy Tab Tablet PC
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jun 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
1937
Points
27
From the home screen press the menu button. Select Settings.
From settings click Wireless and Networks.
You should see the option for enabling Wifi.
After enabling it, you can connect to a network by going into Wi-Fi settings and choosing the applicable network.
2 Related Answers
Azrael SRL
  • 11800 Answers
  • Posted on May 24, 2010
SOURCE: wireless internet access
A wireless 802.11b LAN adapter is included in you tablet, activate it thru Control Panel / Wireless. Unfortunately this is the first generation standard and as such is extremely slow, has very limited range and is no longer supported by a lot of the newer generation devices/hotpoints.
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Aug 10, 2011
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
2answers
Zte tablet model k88 wont connect to wifi
Weak wifi signal or defective tablet or router.
1helpful
Asus tablet is locked out of wifi
Go into settings, turn off Wi-Fi, shut tablet down and wait a couple of minutes then turn back on. After boot up go back into settings turn Wi-Fi back on and see if you can connect to Wi-Fi. If not then the Wi-Fi part of the tablet is probably defective.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
2helpful
My tablet will not connect to my internet
Can't connect to Internet through WiFi on Android Tablet/Phone. ... 4.Try to turn off/on Wi-Fi on the device. Turn off Wi-Fi first, [Settings]>>[Wi-Fi] >>[OFF]. Then turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[ON].
Can't connect to Internet through WiFi on Android Tablet/Phone - Asus
www.asus.com/UK/support/FAQ/1003867 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=tablet%20will%20not%20connect%20to%20my%20internet
I have a nextbook. 7".tablet my Wi-Fi want come on what do I need to do?
go into settings and turn on wi fi if it has wi fi. check aeroplane mode is off. Know WEP or WPA encryption key for Wi FI also if security being used on Wi Fi system.
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
How do I connect my Samsung Galaxy to BT broadband?
Are you trying to connect via wi-fi or via bluetooth? Typical hotspots are wi-fi, and that can be as easy as turning on wi-fi (in Settings, Wi-fi - see manual or quick setup brochure) then waiting for it to find an active hotspot and plugging in any necessary password. Bluetooth is much less common. Post more info and I'll try to help more.
Wi fi not working
Apple products for cell phone and tablet. if yes turn off wi fi on these devices and try reactivating Wi fi. Try changing encryption to WPA rather than WPA2 on wi fi router.had similar problem I solved with apple iphone 5 for a friend I helped.
Wi Fi Problem
Sounds like a bad ios or may be ios get corrupted try to restore the ios file.
My new zte v9 wont connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
