Nikon D70 Digital Camera with 18-50mm Lens Logo
A
Anonymous Posted on Aug 30, 2005
D70 USB setting issue
Why doesn't the D70 show up on my computer like a removable disk?
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 79 Answers
  • Posted on Aug 30, 2005
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
79
Questions
0
Helped
16933
Points
234
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
Laptop running Windows7 previously mounted Nikon D70 (camera) as Mass Storage Device but, stopped recognising it. Camera sees laptop?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Nikon Transfer.
Jul 01, 2012 • Cameras
HOW TO SOLVE BLINKING BLACK SPOTS IN MY NIKON D70
I can duplicate your issue on my Nikon D810. You may have set it to display the areas that are over exposed or "clipped". Go to "Playback Menu", select "Playback display options", uncheck "Highlights".
Hi , My san disk 4gb cruzer micro flash drive has the LED on when i plug it to any computer but doesn't show up on My Computer , Disk management or Device manager . I have tried 3 different desktop...
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
1helpful
My sansa m230 driver mp3 player is not detected as removalble disk i mean as a flash drive on my laptop how can i fix this issue
When you're able to change USB mode in the display:
- From the Main Menu, select Settings > USB
- Select in "Auto Detect", "MTP" or "MSC": choose MSC for viewing the player as a removable disk.
When you cannot select MSC mode in the player's menu, force MSC mode with the player switches/buttons:
1. Turn device OFF.
2. Facing the hold switch: slide it to the right so an orange color would show, putting the device on Hold.
3. Connect the device to the PC with the provided USB cable.
note
In MSC mode: Before disconnecting the USB cable always go through the safely remove hardware icon in the lower screen of your computer on the right. Left click the icon to see all removable disks and left click on the removable disk drive letter of the player to disconnect: after the message you can take out the USB cable.
2answers
Boot failure Asus P5Q-EM
Disk boot failure. Issue:Disk boot failure.
Cause: This issue could be caused by any of the below possibilities.
  1. Boot options are not set properly in CMOS
  2. Non bootable disc or USB in computer
  3. Remove added hardware /check connections
  4. Hard disk drive is bad
Solution:Boot options are not set properly in CMOS
Verify that the boot options within CMOS are set properly. Below is an example of how we recommend the boot options be set. Additional information about how to enter CMOS can be found on document CH00192.
  1. Floppy drive
  2. CD-ROM drive
  3. Hard Drive
  4. Other / Network
Non-bootable floppy diskette or disc or USB in computer
Verify that there is no floppy diskette or disc in the computer. If the boot options are set improperly the computer could be trying to boot from the disc drive instead of the hard drive.
In addition to verifying there is no disc in the computer make sure that no USB jump drive, external hard disk drive, or memory stick is inside any memory card reader.
If you're wanting to boot from a floppy diskette, CD, DVD, or USB drive and are getting this error message and have verified that your CMOS settings are in the proper order as explained in the above paragraph the diskette or disc you're using is either bad or does not have the proper files on it to make it bootable.
  • Additional information about how to make a boot disk can be found on our boot disk help page.
  • See document CH000669 for information about creating a bootable disc.
Remove added hardware / check connections
If you've recently installed any new hardware it's suggested that it be removed to verify it's not causing this issue. If after the device has been removed the computer works and it was another IDE / EIDE device ensure that the jumpers are properly set on the hard disk drive.
In addition to removing any new hardware it's also suggested if you've recently moved the computer or installed anything inside the computer that the connections for the drive be checked. Usually it's best to simply disconnect the cables from the back of the drive and reconnect them to make sure they're connected properly. While inside also disconnect and reconnect the cable connected to the motherboard as well. While inside your computer make sure you're aware of ESD.
Bad hard disk drive
If you have followed the above steps and you continue to experience the same issue, unfortunately it is likely that the hard disk drive is bad or the controller is bad.
If available, you may want to connect another known good hard disk drive to the computer to determine if it can be detected. If it is able to be detected then replace your hard disk drive. If it is not detected, unfortunately you will need to replace the motherboard or controller as it is bad.
If no additional hard disk drive is available it is recommended that the hard disk drive be replaced first or that the computer be serviced / repaired.
D70 will not connect to
I checked all connection and cables and found two issues not related to camera. The USB cable was faulty, replaced and I could connect to computer through F port but the J and I port of the computer continues to not respond and I will need to see what is wrong there.
Mitch
3helpful
Doesn;t taking large files
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
2answers
4answers
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
