Question about Nikon D70 Digital Camera with 18-50mm Lens
What does the fEE error message displayed on an SLR camera mean?
    Novelist:
    Scholar:
  • 79 Answers
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again. The fEE error message Set to f22, or the highest aperture number - normally marked in orange. Note the locking switch.
Posted on Aug 30, 2005
SOURCE:
Why are the letters fEE on my screen when I push the shutter button, and the shutter will not work ?
https://support.nikonusa.com/app/answers/detail/a_id/2605/~/what-does-the-fee-or-f---error-message-displayed-on-an-slr-camera-mean%3F
May 22, 2014 | Nikon D7000 Digital Camera
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
Error code eFF
This normally indicates that you're using a lens with an aperture ring, and the ring is not locked in position. Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it if the lens has a lock. Control the aperture from the body, just as with a lens without an aperture ring.
If the lens doesn't have an aperture ring, could you reply to this post and specify what lens you do have on the D100?
Dec 05, 2010 | Nikon D100 Digital Camera
I got and fEE... and figuered out it means error!!
This might be a long shot, but on the lens section of the guide shown below, it notes ,,,,
Non-G lenses will have an aperture ring on the base of the lens where it's attached to the camera. Set this this ring to the smallest aperture (largest number), usually in orange and 16, 22 or 32. There usually is a lock to keep this ring set there, since if it comes off that setting you'll get an error message (fEE) from most cameras.
Full guide is here:
http://www.kenrockwell.com/nikon/d90/users-guide/index.htm
Hope this helps
Mar 06, 2010 | Nikon N60 35mm SLR Camera
I received an error message FEE on the aperture
You need to have the installed lens set to it's smallest aperture (largest numerically) when using this camera in most exposure modes.
Nov 19, 2009 | Nikon F65 35mm SLR Camera
Error message FEE on aperture
Make sure the lens is mounted on the camer fully. Make sure the aperture ring is set for the largest numbe like 22 or 32 if the lens has it. Some lenses have a lock to lock the aperture ring on the largest number for you. Also make sure the lens you are using is compatible with the F65 camera. if the lens is older then it will not give you any electronic data and the camera will never give you the f information in the viewfinder.
Wont take pictures
The FEE error means that the lens aperture ring is not set to the smallest opening (highest number). The camera body needs it set this way so it has full control of the light reaching the film (or sensor). The lens has a lock mechanism to keep the aperture ring at the smallest opening so you don't accidentally move it when using or changing the lens. On older Nikon lenses, it's a little round button with a white arrow which you push down and rotate to match the arrow with an orange mark. On newer Nikon lenses it is a little slider with a white dot which you can move with your fingernail to match the white with the orange mark.
Feb 19, 2009 | Nikon N65 35mm SLR Camera
Nikon N60 35mm camera error code FEE
Check your lens aperture ring setting. It must be set on the highest number I.E. f16,f22,f32..
Jan 16, 2008 | Nikon N60 35mm SLR Camera
I had the lens mounted
The FEE display means that your lens aperture ring is not set to the F/22 or F/32 ( whichever is at the end of the rotation ). Mount the lens on the camera, then rotate the aperture ring all the way toward the highest number ( 22 or 32 ). If your lens has no aperture ring, the post on the body at the 8 o'clock position of the lens mount is probably broken. It has to be replaced by a repair shop.
Nov 20, 2006 | Nikon F65 35mm SLR Camera
Nikon D70 Digital Camera with 18-50mm Lens Logo
1,340 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
