SOURCE: BAD SMELL FROM OUTSIDE OF REFRIGERATOR
there is sum short circuit in refrigerator wiring, or in the compressor.
Thanks
SOURCE: strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
SOURCE: Large ice block is forming behind the fruit drawer.
i assume you have a model 650 or 550. Your drain line has clogged then frozen. You need to defrost the ice then clear the drain line. I usually knock a majority of ice away then defrost the rest. Once you have defrosted the line you need to clear it. I use high pressure nitrogen to blow them out, but a turkey baster will do just fine. Fill the turkey baster with water, disconnect the drain line from the drain trough. While holding the baster into the drain line squeeze the bulb to force the water into the line. It may take a couple of tries. Reconnect the drain to the drain trough and you should be all set. If you let this go too long the insulation may be saturated and you will have to have a tech install a drain tube heater kit. If you have questions call the factory at 800-222-7820 or go online to the locator page: http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
SOURCE: smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
SOURCE: bad smell from the back
Any drippings in back may cause a funny smell with water settling behind the refrigerator. Pull your refrigerator out from the wall and trace the smell. Maybe your waterline needs to be cleaned.
