Televison & Video Logo
Posted on Aug 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I've recently bought a UMC 40" TV (model: M40/74G-GB-FTCU-UK) and everytime I try to tune it, it just says there is no signal and no channels are found. Everything is connected as it should be. Currently its working but that is via the Sky box which is only on loan at the minute. So I was wondering is there anything that can be done to sort this problem out? Many Thanks
Denkichu
Level 3:
Master:
  • Master 507 Answers
  • Posted on Aug 22, 2017
Denkichu
Master
Level 3:
Master:
Answers
507
Questions
0
Helped
111435
Points
1471
Strange it sounds like there could be more of an issue with the skybox but if you have any RCA cables plug them in and use AV1 or AUX on the tv set however if it has HDMI then plug in a HDMI cable to and from the skybox otherwise check on the back of the skybox and see if there's a channel the TV must be set to
5 Related Answers
Anonymous
  • 372 Answers
  • Posted on Jan 31, 2008
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Anonymous
  • Posted on Dec 15, 2008
SOURCE: technika tv lcd 19-907 tuning in to sky in bedroom.
Hi, with regards the tuning in of the required station I started from the beginning again and after the digital channels had been automatically tuned in it asked if you wanted to tune in the analogue channels . I clicked on the yes button and it tuned in a number of channels and when checking through the channels I found the sky channel required from downstairs which is linked by an aerial connection.
AS Gordon Ramsey would say :------ telly tuned in DONE
Anonymous
  • Posted on Jul 22, 2009
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Anonymous
  • Posted on Sep 10, 2009
SOURCE: Cannot find freeview/digital on our new TV
problem as above please help
Anonymous
  • 325 Answers
  • Posted on Oct 21, 2009
SOURCE: have lost the link from sky+ to a second tv which
Hello K Agate,
In the main room where the Sky + is locate. With the sky remote press the following.
Services.
0,1,select
4 (rf)
Ensure that the RF power to set to on, and take a mental note of the channel number the RF is set to. I normally set this to 38 it is upto you.
Now check that the coax lead that links the sky+ box to the 2nd room is plugged into RF out 2 on the back of the sky+ box.
Now go into the other room and make sure that there is a red LED light on your magic eye. If there is then great. If not there may be a fault with you eye. A good way to check this would be to connect it straight into the back of you Sky+ RF OUT 2 port. This would also check to see if there is any fault with the coax cable feeding the other room.
Assuming that there is a Red LED light on the eye when its plugged into the back of the TV in the other room (not the one with the sky box in), This means that there is power getting to it from the Sky + box.
Put your sky box on the TV GUIDE screen. This will make tuning it in a lot easier.
in the other room with your tv remote press the following
Channel 6 or which ever number you want it on.(analogue)
then MENU on the remote.
Go to MANUAL STORE
Then if you go down to where it give you a C ** number just type in what you retrieved from the sky RF menu.
That should bring your sky up then all you need to do now is STORE.
That should be you all sorted out now.
Hope all goes well. If so then please leave a Thumbs up
Cheers Little Dish Fitter.
Hi, Can any one please shed any light on my problem, When I switch the tv on it says DO NOT POWER OFF and under that SCAN it scans upto 100% then scans again upto 100% and again and again does not stop...
Try a hard reset by unplugging the tv while it is turned on. Then push and hold the power button for a few minutes to drain the electronics and memory of all. Then release button and replug back into outlet and then turn on to see if that has done the trick. If that does not work you can contact tech services for a hidden code to restore unit to factory defaults.
1helpful
CAN I GET NETFLIX ON MY FREEVIEW TV.
If the has an spare HDMI port, you could purchase a Google Chrome Cast. Use it with your WIFI and a Android device to access Netflix.
TV UMC SCAN
Please provide more details. What do you want to know? Gopakumar Gopalan Google
46/188g-gb-5b-ftcu-uk umc tv just keeps saying scanning it goes from 0% to 100% then starts all over again ???? also it is upside down ????? any help would be great
It sounds that the main system memory IC to this set is faulty. Check and replace it. It is a very small IC, having 8 solder terminals, can be located very near to main system control IC. Contact any service technician. If you wish to get some details, check the site linked here.Pull up older posts.
1helpful
39" LED TV MODEL NO: 39/210G-GB-58-FTCU- UK SERIAL NO: UW39D210BFTCUG528-108239 01835
What is the problem you faces with this TV? Provide more details please. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Stuck on scan
It may be that the power cut was the result of a power surge. It may be that the outage has caused damage to the components of
your tv.If it does not return to normal you will need to get a very GOOD technician to diagnose the fault. It may be that the tv can be repaired, it may not ...but eirher way I would think about seeing whether the power company is liable for the damage.
The fault is almost certainly something that needs to be checked out by a pro
6helpful
2answers
No instructions for swisstec 15'' lcd tv
To get a manual for your set, go to;
http://www.umc-slovakia.sk/manuals/index.php
Scroll down to your TV - N15. Click on the language you want to get your manual in.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
