Call services
From your phone, you'll be able to access and change the settings of various call
services for your phone.Contact your mobile operator to find out about the availability of call services.
From the Home screen, press MENU and then tap Settings > Call.
Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this
feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings
Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification
If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode
Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings
Edit the call reject message, choose whether to open the message
editor when you reject a call with a message, and choose whether to
allow automatic saving of an unknown contact number when a call
with that number ends.
Cell broadcast
Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings
Configure channels and language for cell broadcast messages.
Call forwarding
Select how you want your phone to handle busy, unanswered, and
unreachable calls. You can also set the call forwarding option for all
incoming calls.
Call barring settings
Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
