If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
If an iPhone doesn't seem to be charging when plugged in, it may be caused by several reasons. There are four components that could be the culprit: the USB cable, the charger (or power adapter), the charging port or the iPhone itself. Read on this tutorial to fix iPhone not charging issue: https://www.leawo.org/tutorial/why-is-my-iphone-not-charging-when-plugged-in-1409.html?fixya=1409
