The lid switch its faulty bad maby loose wiring
Dear Sir/madam,
The lidswitch may be defective. If it is, the washing machine doesn't spin.The switch is inside the washing machine main housing near the doorframe. Often you have to raise or open the top or front of the washingmachine to get to the switch. If it's defective, you need to replaceit.
If the lidswitch is defective, the washing machine may not agitate or function atall. The switch is inside the washing machine main housing near thedoor frame. Often you have to raise or open the top or front of thewashing machine to get to the switch. If it's defective, you need toreplace it.
Details for How to maintenance? etc... Click this link for all information........
http://www.repairclinic.com/0088_11_1.asp#Level2_9
Thanks
good luck
Under your lid if you lift it up. there is a switch. you need to make sure that the switch is being depressed completly when it is the cycle. since you can press on the lid and the cycle will restart it's self you will need to change that switch and or put something there that will depress it so will keep through the cycle.
If your washer stops periodically during a cycle, it probably means that your timer is bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Are you getting error message or flashing lights in the washing unit ,,,
Please use this link:
http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=2320&p_created=1190316720&p_sid=CPPrJ1cj&p_accessibility=0&p_redirect=&p_lva=70&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjAsMjAmcF9wcm9kcz0yOTMmcF9jYXRzPSZwX3B2PTEuMjkzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9bWFjaGluZSBzdG9wcyBwZXJpb2RpY2FsbHkgZHVyaW5nIGN5Y2xlLi5JZiB5b3UgcHJlc3Mgb24gbGlkIGl0IHJlc3RhcnRz&p_li=&p_topview=1
Good luck...
You would need to replace the motor. Go to the link to order them:
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60AWashingMachine
Thanks
Your lid switch is bad or gong out by u stating you have to push down on the lid to get it to start replace the lid switch if you need to know how post your email i will send you instructions
Part number for the lid switch is 3949247
check your email you neen to remove the cabniet to access it
Thanks for the Rating !!
Www.repairclinic.com
the above link will help u get more information on solving ur problem.
also check whether its the problem of lid sensor.thanks n pls do rate the solution.
Have a look over here
common washing machine problems and solutions there, also replacement parts available.
Whirpool Super Capacity Plus
Model LSQ8543JQO
I'm not sure how long it takes to get a reply.
What repair parts do I need to fix this problem?
Since I'm not a washing machine repair person I was hoping someone could help identify what parts need replaced.
E-mail address is [email protected]
Thanks so much
Replacing the motor doens't make any sense. The problem is with the lid.
No.
Okay but if we press on the lid it restarts immediately..Would that be an indication of a bad timer ?
Makes sense but, where is the switch. If I just lift the lid I don't see anything.
Thank you I'm going to purchase a new swtich
