Question about General Electric WCVH6800J Front Load Washer
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
    Scholar:
  • 44 Answers
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Posted on Jul 28, 2011
SOURCE:
Is it expensive to replace the control board for a frigidaire front load dryer? There is LOC code showing up
The cost of the control panel will depend on the model. Usually these cost $200-300.
However, the LOC often indicates a control panel lock is enabled. Try looking at the control panel for a button with a padlock symbol in a small font on or below the button or a pair of buttons connected by a line below the buttons with the padlock symbol in the line. Press and hold the button or pair of buttons for 10 seconds. On the Frigidaire FFQE5000QW, the buttons to press are Options and Select.
I hope this helps. Please add a comment with the model number of your dryer for more accurate information on the control panel and the control panel lock.
Mar 26, 2018 | Frigidaire Washing Machines
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
When i Press start the washing machine clicks a few times then red padlock light comes on. Door interlock changed but still happening. Any help appreciated.
I gather that the interlock has been replaced and now the padlock symbol lights up plus some clicking. I think the clicks are the door lock engaging and the padlock just shows this. Do the clicks continue? Does the door stay locked? If so I believe you have a fix.
May 19, 2015 | Indesit Washing Machines
HOW TO CLEAR THE LOC CODE ON MY FRIGIDAIRE WASHER
This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
I hope this helps.
(the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
Nov 23, 2011 | Frigidaire 14 Cycle Tumble Action Washer
HE3 front load washer has "control Blocked" light is on. No button works on control panel.
You have locked the control via the "Child Lock." Look for the button with a small padlock icon on it, press and hold for about 4 seconds to unlock. That should fix ya!
Sep 11, 2010 | Kenmore HE2 Plus Front Load Washer
MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Feb 07, 2010 | General Electric WCVH6800J Front Load...
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Red light padlock symbol? what does it mean
the padlock led indicates that bthe door is open or poss interlock fault, however since you said it now trips fuses, IF you are not electrically minded call an expert something could of become disconnected or moisture could of got into the machine and blown the module
Jan 09, 2007 | Indesit WA 125 Front Load Washer
General Electric WCVH6800J Front Load Washer Logo
2,037 people viewed this question
Top General Washing Machines Experts
Kevin
Kevin
geapptech
Dw Wooten
Dw Wooten
Are you a General Washing Machine Expert? Answer questions, earn points and help others
